September 10, 2010, 11:28 |
Propeller Effects on R/C model Plane
Waqas
I am desigining a 6ft span R/C airplane required to carry a 2 kg payload with 25 mins loiter. Now i want to estimate its lift through CFD, since I can't any good maths for predicting Low Reynold Number lift.
can any any body tell me that how will i simulate the propeller effects on my R/c plane. The data i have is the prop diameter, RPM adn Power. Which B.C should i use and how to model that condition in my geometery! I am Using Gambit 2.4 and Fluent 6.3! |
September 10, 2010, 14:46 |
Andrew
Rep Power: 18 |
wouldn't you want to make sure that at the specified RPM of the motor your prop blades are generating enough lift to pull the plane forward at the required speed necessary for the plane's wings to develop enough lift to make the airplane fly with the required load?
If that is the case, and I had to do it in Fluent, I would do a study of the lift generated by flow over the prop blade and find the necessary velocity to get the lift I needed. Unless I missed something, that is what I would do. |
September 10, 2010, 15:18 |
Waqas
Actually i want to see that if my design is flown at a specific speed then how much lift will it generate ... and then if the propeller effects are added then how much will be the difference (I am assuming that my prop and rpm are generating enough thrust to fly at that specific speed)
September 10, 2010, 15:36 |
Andrew
Rep Power: 18 |
do you have a cross-section of your wing? That would be the easiest way to do it. If it is a standard wing you can probably find a lot of data already dealing with that specific wing. You can also check your pitch etc.
What do you mean by 'propeller effects'? |
September 11, 2010, 00:21 |
Waqas
At certain Angle of Attacks the prop wash tends to decrease the effective AoA just like downwash. So I want to estimate that effect on my plane!
Use of k-epsilon and k-omega Models | Jade M | Main CFD Forum | 40 | January 27, 2023 07:18 |
Propeller Fan Curve Simulation | Teng_YJ | FLUENT | 2 | February 16, 2009 19:37 |
azimuthal angle in plane orifice atomizer model | sina | FLUENT | 0 | September 23, 2008 01:23 |
Radiation effects in model | Ken | Siemens | 8 | August 7, 2003 14:28 |
