May 7, 1999, 13:47 |
cfd model of a leaking valve??
Is it possible for cfd to model a leaking valve that contains such a small gap between valve disc and valve body? Can I restrict the cfd inlet velocity to simulate the small leakage rate of 20 cc/hr to 120 cc/hr?
May 7, 1999, 14:56 |
Re: cfd model of a leaking valve??
(1). There is no limit on the size of the gap, there is no limit on the Reynolds number. (2). There is even a new field called "micro-fluid dynamics"- fluid dynamics in micro devices.(see ASME Journal of Fluid Engineering, recent issue? Also Journal of Tribology.)
May 10, 1999, 11:44 |
Stephen,
I am sure CFD can do it. But if I were you I wouldn't bother to do CFD for such small flows use a annular leak equation and calculate the pressure drop (if thats what you want to find). Q = pi*(bore dia) *(radial clearance).^3 *(delta p)/ (12*mu*length) Anil |
Best CFD software to model phase change | ana | Main CFD Forum | 5 | June 10, 2009 07:43 |
CFD of reed valve | sachin | CFX | 0 | December 27, 2005 03:04 |
CFD siphon model | J Gassaway | Main CFD Forum | 3 | February 22, 2005 02:05 |
ASME CFD Symposium, Atlanta, July 2001 | Chris R. Kleijn | Main CFD Forum | 0 | August 21, 2000 04:49 |
CFD Application in hydraulics valve flow | Roger Yang | Main CFD Forum | 11 | February 11, 1999 16:53 |
