help for the Fastran
Old   October 20, 2010, 01:51
Question help for the Fastran
june_zhazha is on a distinguished road
I use CFD-Fastran to compute the lift force and drag force of the AGARD-B model at Ma=1.5, total temperature T0=288k, dynamic pressure Q=62Kpa conditions, at first it converges very well. But after perhaps hundreds or thousands steps(according to the CFL number), the residual errors suddenly increase in few steps, and then, in some steps ,the process was terminated for the divergence regardless of magnitude of the CFL number. I think it was irrelevant with the grid, because i used the same grid to compute by Fluent, it could converge.
Could someone give me some advices?
june_zhazha is offline   Reply With Quote
Old   October 20, 2010, 02:14
Charles
CapSizer is on a distinguished road
It's been a while since I've worked with CFD-Fastran, but my experience is that it works well with grids that are very different to the ones that Fluent likes. Is this a structured or unstructured grid? Things may well have changed since I last used it, but the structured Fastran solver worked much better for me than the unstructured one.
CapSizer is offline   Reply With Quote
Old   October 20, 2010, 06:38
Exclamation
I use structured grid. Y+~40
Old   October 20, 2010, 11:42
Charles
Try running it to full convergence with a first order differencing scheme, then go to a higher order scheme (Van Leer?).
Old   October 21, 2010, 05:04
I usually use fisrst order differencing scheme (Roe or Vanleer) to initialize the flow field, and then go to a higher order scheme. But finally the result is divergence. Does anyone meet this problem? And how is it resolved?
Old   October 30, 2010, 11:41
Default Same troubles
simulationman is on a distinguished road
I am using ACE+ which is essentially from the same group. And I do face such problems.
Now ACE+ does provide an output file. Seeing that I found that the problem actually started a few steps before the actual increase of the residuals and consequent divergence. The problems were like limits of variables were reached or the maximum number of sweeps for a particular variables were reached.
So when that happens, I usually just increase the relaxation and it works out fine. Maybe the same solution applies for Fastran.
simulationman is offline   Reply With Quote
fastran
esi fastran gui problem minnymoony Main CFD Forum 0 October 27, 2009 06:56
CFD-GEO& FASTRAN tutorials BEKNA Main CFD Forum 0 November 5, 2007 12:51
CFD FASTRAN enri Main CFD Forum 2 December 19, 2006 12:11
Flow over flat plate using FASTRAN AndyLiu Main CFD Forum 1 August 7, 2006 08:02
FASTRAN boundaries sile Main CFD Forum 0 June 27, 2006 08:21
