November 28, 2010, 04:44 |
Boundary conditions low Mach number flow
I'm trying to study a low Mach number flow with variable density using the SIMPLER algorithm. The real problem is that of a spherically expanding flame from a point source in an unconfined space. The physical boundary conditions are the velocity u=0 at the origin and u=0 at the far-field and pressure p=p0 at the far-field. The problem is essentially 1-D so I use a 1-D domain with a staggered grid for computations. It is my understanding that for such a problem I only have to define either pressure or velocity at the boundaries. I seem to be getting incorrect results and I think I have issues with boundary conditions. Right now I have, at the centre, r=0, u=0 at the far-field, r=R, du/dr = 0 I use the discretised pressure equation to obtain the pressures at the boundary using the velocities calculated at the boundary, i.e. I don't specify a particular pressure value at the boundary, it is taken from the solution. Can anyone tell me if I'm doing anything wrong? Thanks. |
bcs, simpler algorithm |
non reflective boundary conditions for incompresible flow | Pascal_doran | OpenFOAM Programming & Development | 16 | August 25, 2015 05:35 |
Proper Pressure Boundary Conditions for Buoyant Flow | mchurchf | OpenFOAM | 0 | March 25, 2010 12:16 |
Concentric tube heat exchanger (Air-Water) | Young | CFX | 5 | October 6, 2008 23:17 |
Outlet boundary conditions for unsteady flow | Bjorn B | Main CFD Forum | 3 | January 11, 2006 05:42 |
Low Mach Number Flow | Mohammad Kermani | Main CFD Forum | 0 | February 24, 2002 23:47 |
