I am working on a Research code, and the first step of work assigned to me is to change the steady state code to Unsteady one. I heard that to start with, it is good to try a fully implicit one, as the modifications required(in the code) is very less, but still i face some problems in doing so, can any one help me in going about it ??? I have some modification done, to convert the code to unsteady, can any one let me know how to validate the same, with a simple test case ? Hope things are clear, let me know if u need more clarifications. Krishna. |
on this site there is a resourse link .. there u have link to benchmark case ..u can try them
For a first test, you might try to get the new code to reproduce a steady problem done with the original code.
A good way to go is the probably this:
Take a steady solution as the initial condition (say Couette Flow at low Re) and march in time. You don't want to pick flows that go unstable quickly or flows that are highly sensitive to numerical dissipation. If your solution goes unsteady, you have a bug in your code. |
Solver for transonic flow? | Martin Hegedus | OpenFOAM Running, Solving & CFD | 22 | December 16, 2015 04:59 |
CFX steady simulation | gharek | CFX | 1 | April 7, 2010 18:41 |
How to determine whether flow is steady or unstead | Maliya,Barth | Main CFD Forum | 7 | October 7, 2006 02:26 |
about the steady solution | zwdi | FLUENT | 0 | August 29, 2003 10:34 |
steady or unsteady? (in dpm) | winnie | FLUENT | 1 | April 28, 2003 11:30 |
