pointcare index
Old   November 1, 2004, 00:29
Default pointcare index
autofly
hi I meet difficulty in understanding the definition of pointcare index. when study the topotical structure on surface. the sum of saddle and nodal points must meet certain relationship. for a common case.sum( N) -sum(S) = 2 but for special case sum(N) + 1/2 sum(N')- sum(S) - 1/2 sum(S')= I
I is the pointcare index. how to get it?
in a formula I = D-phi/2*pi, i dong't know how to get the phi? who can give me detailed intepretation? thanks
Old   November 6, 2004, 22:57
Default Re: Poincare index
versi
Your first formula is right , but your second formula about relation of Poincare indices in 2D should be sum(N) + 1/2 sum(N')- sum(S) - 1/2 sum(S')= -1 , where N is a full node or focus point or center point, S is a full saddle point, N' or S' are half node (saddle) point on the boundary of the 2D domain. The index of a full node = 1 while the index of a saddle =-1, the index of a node (saddle) on the boundary is counted as 1/2 (-1/2). The meaning of Poincare Index can be found in many text books about topology and dynamic theory. If you draw a closed loop around a critical point and monitor the direction change of the unit field vetor along this loop counterclockwise, if change of the direction of the unit field vector is counterclock +360 (or -360) deg , then Poincare index =+1 (or -1).
Old   November 8, 2004, 13:32
Default Re: pointcare index
Nicola
For a general surface, the sum(N)-sum(S)=2-2*g=I where g is the number of holes in the surface. So, for the flow over a sphere I=2, for the flow over a thorus I=0.
Hope it helps,
Nicola
gamma-ReTheta turbulence model for predicting transitional flows FelixL OpenFOAM Programming & Development 123 August 30, 2022 11:50
centricity index, uniformity index LeonardLapis Main CFD Forum 5 August 26, 2015 23:46
Doxygen documentation Tanay OpenFOAM Installation 9 September 23, 2011 11:40
OpenFOAM install on Ubuntu Natty 11.04 bkubicek OpenFOAM 13 May 26, 2011 05:48
Dryden index fjalil Main CFD Forum 0 July 7, 2010 11:33
