Question on runge-Kutta scheme
Old   December 22, 2010, 12:58
Default Question on runge-Kutta scheme
lost.identity is on a distinguished road
I'm trying to solve a low Mach number, variable density flow using SIMPLER algorithm of Patankar. It's an unsteady problem where I've used first order Euler backward scheme for the time discretisation. I use a time-marching technique to advance the solution in time.
I'm wondering whether it is possible to implement a fourth-order Runge-Kutta scheme together with SIMPLER.
THanks.
lost.identity is offline   Reply With Quote
Old   December 22, 2010, 13:40
DoHander is on a distinguished road
The backward Euler scheme is actually a particularization of a Runge-Kutta scheme (order 1). In principle you can use a Runge-Kutta scheme for the time discretization.
DoHander is offline   Reply With Quote
Old   December 24, 2010, 20:48
Default the potential problem of RK method
Wu Jian
harbinyg is on a distinguished road
Send a message via MSN to harbinyg
as it is unsteady problem ,
your starting point should be higher accuracy in time.
but if you use high order RK method of, or AB method is the same, assuming you using explicit version
then there is a limitation of time step for stability consideration...
so , if you need higher accuracy, three time level method should be a good choice
in fact, the whole accuracy should both consider spatial and temporal terms
if it is second order in spatial, there is no need for 4th order temporal scheme
harbinyg is offline   Reply With Quote
AUSM scheme ? Central Scheme boling Main CFD Forum 7 January 7, 2016 02:41
2N Storage runge kutta Vasanth Main CFD Forum 3 August 2, 2005 10:44
Question about meshing / solution scheme of CFX Coriolius CFX 8 August 1, 2004 18:39
Scheme documentation and question Mickaël Perrin FLUENT 0 July 4, 2002 05:21
Diagonally Dominate Runge Kutta Method Anthony Iannetti Main CFD Forum 0 January 23, 2001 21:27
