pressure boundary condition in AVL FIRE
Like Tree1Likes
  • 1 Post By doki
Old   January 16, 2011, 02:39
Angry pressure boundary condition in AVL FIRE
doki is on a distinguished road
I am performing numerical modeling of gas injection Through a single hole nozzle into a closed chamber with avl FIRE. I intend to define a Total Pressure at inlet of Injector, but the solution does not show any sensitivity to the boundary condition set. It appears that the boundary condition does not "penetrate" into the domain. I have checked almost everything and all the solution setting seems to be appropriately set.
The flow velocity at nozzle exit for pressure ratio of 20 between inlet and chamber is only 2 m/s in first time step!!!!! so definitely sth basic is wrong.
I would be grateful if anyone help me through the staff.
neu likes this.
doki is offline   Reply With Quote
Old   January 20, 2011, 08:20
Morshed Alam
morshed_alm is on a distinguished road
You can try with stagnation pressure boundary condition at the inlet and static pressure at the outlet. .
morshed_alm is offline   Reply With Quote
Old   January 30, 2011, 05:53
there is no outlet in the domain.
Stagnation pressure boundary condition needs Mach Number and Dynamic pressure be set at inlet. these values are actually the solution results! i.e. one can not determine them at first.
anyway, I have checked almost everything in the solution and got nothing!
Old   December 21, 2011, 16:39
Default gas injection in AVL fire
neu
neu is on a distinguished road
Hi doki
I also have similar problem to you. I want to inject gas from 1mm diameter nozzle to a constant volume chamber.
What boundary conditions should I use?
Would you please tell me about important adjustment for getting good results?
Thanks,
neu is offline   Reply With Quote
Old   December 22, 2011, 12:07
Generally the pressure boundary conditions result in slow convergence. you SHOULD adjust the time step size, the URFs and even the number of iterations per time step.
other settings depend on the type of flow. I mean if the flow is under-expanded or not.
Old   December 22, 2011, 12:17
neu
Hi Doki
Thanks so much.
You mean that the total pressure boundary condition is not good.
What boundary condition do you suggest?
Yes, my flow is under expanded. I mean that the injection pressure is nearly 100 atm and the chamber initial pressure is under 10 atm.
1- I use from simple method.
2- My time step in intial stage of calculation is 1e-07 and the gradually reduces to 2e-05.
Would you Please help me?
Old   December 27, 2011, 01:27
It is meaningless that a boundary condition type is not "good". it just might not be appropriate. in some cases you SHOULD use total pressure boundary condition. in each case you should adjust the required settings to get the best convergence.
Anyway, the pressure boundary conditions are a kind of "slow" in convergence.
Old   December 27, 2011, 12:52
neu
Hi doki
Thanks. I have some question:
1- How many Min. number of iterations are need for good convergence?
2- Is it need that I active Second order option in Run mode section?
3- What about for activation of two stage pressure correction?
4- What should I choose in compressibility section between compressible, subsonic and supersonic?
Best,
Pressure boundary condition C-H Kuo Main CFD Forum 18 September 16, 2016 03:19
how can i give a boundary condition with pressure and velocity together akhenathon FLUENT 6 April 24, 2012 18:32
Pressure Boundary condition abishek FLUENT 1 July 28, 2008 08:14
Pressure boundary condition and real gas Pifou FLUENT 0 July 19, 2005 11:42
