January 18, 2011, 01:49 |
backward facing step problem
Yin
I tried to solve incompressible NSEs on lid cavity problem and the results look fine (simple algorithm, collocated). However, when I switch to backward facing step problem, the solution can not converge. The things confuse me most are the boundary conditions of pressure correlation/velocity-u at inlet and outlet. So, is there any one can make a short summary for me about the correct BC setting for backward facing step problem. Thanks in advance! |
January 18, 2011, 08:58 |
#2 | |
Morteza
Rep Power: 16 |
Send me a copy of your code ...i will send you the modified code morteza08@gmail.com |
Backward facing step; x/H; U/U0; diemsionless analysis; paraview | idrama | OpenFOAM | 1 | December 3, 2013 17:10 |
backward facing step flow | student | Main CFD Forum | 6 | June 9, 2013 11:17 |
Backward Facing Step on buoyantSimpleFoam | tetsuro86 | OpenFOAM Running, Solving & CFD | 0 | June 9, 2010 17:10 |
backward facing step flow | gopinath | Main CFD Forum | 0 | January 22, 2005 05:02 |
backward facing step flow | senthamarai kannan | Main CFD Forum | 0 | January 22, 2005 05:01 |
