question about foil of sailboats.
Old   January 19, 2011, 20:33
Default question about foil of sailboats.
sail's Avatar
Vieri Abolaffio
sail is on a distinguished road
Dear all.
i was wondering why the new sailboats have keel profiles concave in the aft part. given all parametrs equal, my analysis using xfoil show better results (especially in terms of drag) of foils without concavity. those foils must be symmetric and are supposed to work at Re around 2 or 3 million at 3° aoa. attached you'll find the images of those keels.
thanks for your help
sail is offline   Reply With Quote
Old   July 25, 2011, 10:18
Dave
daveatstyacht is on a distinguished road
Sail,
On foils that are design for a large extent of laminar/transistional flow a primary issue is flow separation in the region of pressure recovery (adverse pressure gradient). To combat this, a rapid initial recovery where the boundary layer is still stable is used followed by a slower final recovery up to the trailing edge hence the rapid concave shape followed by the shallow region towards the trailing edge. I believe Principles of Yacht Design by Larson may contain a brief description of this. A more detailed description can be found in the 8th CSYS symposium paper "Keel Design For Low Viscous Drag" by Obara and van Dam. My guess is your results may be the result of bypass transistion due to improper free stream turbulence intensity if you are using a transistion model (e^n model).
Regards,
Dave
daveatstyacht is offline   Reply With Quote
Old   July 26, 2011, 05:08
sail's Avatar
Vieri Abolaffio
thanks for the references, i will look them up!
Unanswered question niklas OpenFOAM 2 July 31, 2013 16:03
Question about Table applicaiton. universez OpenFOAM Running, Solving & CFD 0 January 12, 2010 20:31
Poisson Solver question Suresh Main CFD Forum 3 August 12, 2005 04:37
CHANNEL FLOW: a question and a request Carlos Main CFD Forum 4 August 23, 2002 05:55
question K.L.Huang Siemens 1 March 29, 2000 04:57
