Programming a mesh
Old   January 21, 2011, 00:37
Default Programming a mesh
Dimitar Kirilov
m0t0r0ne is on a distinguished road
Greetings,
I was told that Matlab can be used for programming the mesh for CFD problems instead of, shall we say, FORTRAN. What about Maple? Does Maple have the same capability? The reason why I am asking is that I have a little experience with both Maple and Matlab and I want to decide on which one to concentrate, at least when it comes to programming and not using commercial software.
Thanks
m0t0r0ne is offline   Reply With Quote
Old   January 21, 2011, 11:20
DoHander is on a distinguished road
Maple and Matlab are both Turing complete programming languages, which means you can basically can program anything in them (almost), probably you should ask yourself in which of them it will be easier for you to implement the mesh generation code.
Do you plan to implement a unstructured mesh generator ? If yes, Matlab has some nice functionality to create a Delaunay triangulation from a set of points.
Do
DoHander is offline   Reply With Quote
Old   January 21, 2011, 11:41
Default Thanks
Dimitar Kirilov
Thanks,
That really helps. I am not planning anything in particular yet, since I am at the very beginning of my project, but a lot of the people I know are using Matlab, so I'll probably go with that too.
Thank you for the help and the advice.
Old   January 21, 2011, 15:48
You can also use an existing mesh generator, like the one included in FreeFEM++ distribution, it will give you 2D triangular meshes.
Do
Old   January 22, 2011, 13:41
Dimitar Kirilov
OK, I'll try it.
Thanks again.
Old   January 23, 2011, 06:17
walli is on a distinguished road
You can also have a look at the GMSH [1] mesh generator; there is also Netgen for generation of unstructured meshes [2]. If you consider programming in C++ rather than Matlab someday, I can recommend the DUNE interface [3] for mesh handling. A good overview can be found in [4]...
[1] http://www.geuz.org/gmsh/
[2] http://sourceforge.net/projects/netgen-mesher/
[3] http://www.dune-project.org/
[4] http://www-users.informatik.rwth-aac...eneration.html
walli is offline   Reply With Quote
Old   January 23, 2011, 12:59
Dimitar Kirilov
I'll check it out. I am an absolute newcommer to CFD and right now I am looking for something to get started with. My supervisor mentioned that programming in 'something like C++ or Fortran' is preferable, but he did not point out anything in particular and this 'something' could mean anything. I can imagine that there is no 'best' choice when it comes to handling combustion problems, so I guess in the beginnig it will be OK if I get familiar with at least one of the above solutions be it Matlab or C++ or something else.
Thanks for the advice and for the links.
Dynamic Mesh Problem. Tom Clark FLUENT 10 June 21, 2021 04:27
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
mesh missing after export in gambit morteza08 ANSYS Meshing & Geometry 1 July 26, 2010 01:10
2d irregular grid Remy Main CFD Forum 1 December 22, 2008 04:49
basic of mesh refinement arya CFX 4 June 19, 2007 12:21
