Fluid flow in porous material
Old   January 31, 2011, 06:31
Default Fluid flow in porous material
martin beer
bjorson is on a distinguished road
Hello, I need advice for the simulation of fluid flow in porous material. Material has a simple block shape. Pore size is 110 μm 220 μm 330 μm 550 μm 1000 μm 1600 mm. Needs to calculate the fluid pressure in the porous materials, and also a graph of pressure. What software is on the simulation of most appropriate? I will be grateful for any idea.
Thank you
bjorson is offline   Reply With Quote
Old   January 31, 2011, 07:33
Mak
trinath2rao is on a distinguished road
Hi bjorson,
I think PORFLOW from ACRi-CFD
will give better simulation in porous media..As This software is specialised in Solving problems involving transient or steady state fluid flow, heat, salinity and mass transport in multi-phase, variably saturated, porous or fractured media with dynamic phase change.
As your problem dealing with fluid flow through pores, fractures . I recommend PORFLOW software.....
For more detail U can check http://www.acricfd.com/
Hope It solves your Problem
trinath2rao is offline   Reply With Quote
flow thru porous media, PLEASE HELP Goker FLUENT 4 September 8, 2012 04:02
Porous Media coupled with internal flow Samuel Andrade FLUENT 2 August 26, 2012 09:43
Porous media flow with diffusion albertinho OpenFOAM 0 March 31, 2010 17:14
using ANSYS workbench to model fluid flow in a porous structure mealyj CFX 0 January 25, 2010 14:18
