December 30, 2004, 05:44 |
CFD in paachutes
Hi everyone!
I m an undergrad interested to obtain a solution for a ram air parachute/payload system....while it is pitching up under aerodynamics forces... but for a partcular time instant.. it takes a lot of time to reach steady state.... is there some way by which i can incorporate unstady effects.... can Fluent do that?? waitin for a reply Yogesh babbar pec, chd |
December 30, 2004, 07:32 |
Re: CFD in paachutes
http://www.mems.rice.edu/TAFSM/PROJ/FSI/axi_para.html
Hi, This site may be of interest to you. It is the only site dealing with parachutes. The method used here is finite-element. Get a galarkin-based code for it. You can try Rheolef for it. You can try using Fluent deforming mesh feature but it will be a unsteady feature. Regards A.S. |
January 3, 2005, 09:14 |
shape of inflated Ram AirParachute
Hi Everyone,
I am interested in performing a CFD analysis on A Ram air parachute in steady state..If anybody can help me out on the geometry to be anlysed.. I need to know the equations defining the surface of the various surfaces of cells of the parachute.. if possible... or any suggestions... for approximations thanks Yogesh Babbar |
January 5, 2005, 11:20 |
Re: shape of inflated Ram AirParachute
You can look into LS-DYNA. I have quite a few people using LS-DYNA to do this type of simulation. Pei-Ying Hsieh |
CFD Wiki - We Need More Help! | Jonas Larsson | Main CFD Forum | 0 | September 26, 2005 08:11 |
Where do we go from here? CFD in 2001 | John C. Chien | Main CFD Forum | 36 | January 24, 2001 21:10 |
ASME CFD Symposium, Atlanta, July 2001 | Chris R. Kleijn | Main CFD Forum | 0 | August 21, 2000 04:49 |
Since Last June | John C. Chien | Main CFD Forum | 3 | July 12, 1999 09:38 |
Which is better to develop in-house CFD code or to buy a available CFD package. | Tareq Al-shaalan | Main CFD Forum | 10 | June 12, 1999 23:27 |
