Heat transfer through the porous media.
Old   February 23, 2011, 01:16
Default Heat transfer through the porous media.
Fairuz Hafizan
fairuz_hafizan is on a distinguished road
Hye, actually i would like to know, is there will be temperature drop when the fluid such as air through the porous media such as water? If yes, how i can set the important parameters in porous media?or what else the important which i need to follow? I already create the simple of 2D geometry which is the air was flow through the porous media (10cm) and exit that medium. Actually i was try to simulate but there is not pattern of the temperature drop..
fairuz_hafizan is offline   Reply With Quote
heat transfer in porous media Miko Siemens 10 February 16, 2022 07:13
heat transfer to porous media... club68512 FLOW-3D 5 November 3, 2010 23:20
Conjugate heat transfer problem with porous media piko Siemens 1 April 17, 2009 15:41
heat transfer with porous media gokul FLUENT 0 February 24, 2009 13:43
REG POROUS MEDIA HEAT TRANSFER Rashmi Venkat FLUENT 6 June 1, 2006 05:13
