February 2, 2005, 04:20 |
3D Panel Method Code
I am searching for 3D panel method code for subsonic flow for arbitrary body. Can anybody provide me source code for arbitrary body. Thanks A.S. |
February 2, 2005, 05:12 |
Re: 3D Panel Method Code
Have a look in this book, it has FORTRAN source code which should help you.
"Low Speed Aerodynamics" by Joseph Katz ISBN: 0521662192 Hardcover 2001-02-15 Cambridge University Press http://www.gettextbooks.com/isbn_0521662192.html |
February 2, 2005, 06:25 |
You can get a host of aeronautical software, including PANAIR, a "High order aerodynamic panel code. The most versatile and accurate of all the linear theory panel codes. Subsonic/supersonic solutions with linear source strength variation and quadratic doublet strength variation" ... as advertised, in:
http://www.pdas.com/ PANAIR was developed by Boeing. |
February 2, 2005, 07:49 |
Hi James,
Thanks for your help. A.S. |
2D Field Panel Method Source Code | Shukla | Main CFD Forum | 3 | January 20, 2011 12:51 |
Why use a panel method? | gocarts | Main CFD Forum | 2 | April 22, 2007 22:50 |
Problem building 3D Panel Method | Daniel | Main CFD Forum | 0 | September 15, 2006 07:51 |
help 3D panel method | luca | Main CFD Forum | 0 | June 22, 2004 04:16 |
calculating missle configuration by panel method | Daniel | Main CFD Forum | 5 | January 6, 2003 08:09 |
