Comparing spallart-allmaras, k-epsilon, k-omega models
Old   March 30, 2011, 14:45
Default Comparing spallart-allmaras, k-epsilon, k-omega models
glex1308 is on a distinguished road
I've performed several analyses of flow over a symmetrical wing profile using Star-ccm and used three different turbulent models (RANS: spallart-allamaras, k-epsilon and k-omega models). From the results all 3 give almost identical velocity vector plots but begin to differ for pressure and turbulent viscosity plots.
I was wondering if anyone can explain why the peak pressure at the front of the wing is higher for spallart-allmaras then for both k-epsilon and k-omega models?
The results for turbulent viscosity around the airfoil are also very different between k-epsilon and k-omega models. The turbulent viscosity values for the k-epsilon model change a lot from the surface of the wing to the domain boundary but the k-omega model there is an almost zero value surrounding the wing and then changes value. Wondering if anyone knows why the k-omega values close to the surface are all identical?
Thanks in advance
glex1308 is offline   Reply With Quote
Bounding epsilon or bounding omega Stylianos OpenFOAM 8 February 23, 2018 13:41
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 16 March 4, 2017 08:30
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 1 November 25, 2008 20:21
extracting K and Epsilon from Spalart Allmaras Sundar Main CFD Forum 4 July 31, 2006 02:02
comparing different models and grids Philipp Main CFD Forum 4 August 31, 2001 04:14
