Hi all,
I am looking for some info(papers/weblinks) on finite difference or finite volume schemes (preferably higher order) for Stream-function vorticity formulation in 2-D generalised curvilinear coordinates. Thanks in advance, Abhijit. |
dear Abhijit
my master is in the subject which you ask about ,what you want to know exactly. thanks khairy-Egypt |
Hi ,
Thanks for your response. I would like to know what schemes/methods you used and what are the references. If you have a electronic copy of your masters thesis/paper that would be great. you can email it to me at tilak_abhijeet@rediffmail.com. Thanks Abhijit. |
dear Abhijit i used generalized coordinates to steady the flow over any two dimensional body ,or inside any two dimensional enclouser. any result or source code using fortran 90 will be avialable after discussion of my thesis after few days, before that what is the main problem with you. thanks khairy-Egypt
hello khairy,
thanks for your response. I want to know if you used finite-volume method or finite difference method ? What scheme (first order upwind/or higher order upwind schemes)you used? what books/journal papers you used to write your code? I will be writing my own code. I have'nt come across any major references using finite-volume method for stream-function vorticity formulation. Most books I describe first order upwind scheme for vorticity transport equation. I am looking for something better. Thanks Abhijit tilak. |
Hello Abhijit i used finite difference method ,the main reference are "Al-Bahi, A., M., and Abdelrahman, M.M. ,(1993). "Numerical Solution of The Unsteady Incompressible Navier-stokes Equation in Generalized Non-Orthogonal Curvilinear Co-ordinates", fifth ASAT Conference, Cairo.", "Hoffmann, K., and Chiang, S.(1995)"Computational fluid Dynamics for Engineers", engineering Education System, Wichita, USA."(first volume) i use second order upwind scheme using image point(i derive the vorticity at the wall by myself with the assistance of my advisor) i have three version of my code 1-uniform grid,2-stretched grid,3-generalized can i give you an advice from my little experience in CFD "use finite volume-primitive variables "if you intended to write the code use the following two books 1-An introudiction to computional fluid dynamics the finite volume method,by Versteeg and Malalasekera1995 2- computional methods for fluid dynamics,by Peric(the used codes are avialable via (ftp://ftp.springer.de/pub/technik/peric)1999
Hello khairy,
Thanks a lot. I will look at the references you have given. It would be of great help if you can email me a PDF/MS WORD file of your Masters thesis/research report. My email address is tilak_abhijeet@rediffmail.com. Thanks, Abhijit |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 09:31 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 06:42 |
latest OpenFOAM-1.6.x from git failed to compile | phsieh2005 | OpenFOAM Bugs | 25 | February 9, 2010 04:37 |
Error with Wmake | skabilan | OpenFOAM Installation | 3 | July 28, 2009 00:35 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
