Recommendation for mesh generation software
Old   May 25, 2011, 11:15
Question Recommendation for mesh generation software
Tibi Chelcea
tibich72 is on a distinguished road
I'm looking for a new mesh generation software and I'm asking for some recommendations. Let me describe what we do and what we need.
Our current simulation setup is entirely batch driven; the interface is on the web. Based on user inputs and our own library of components, we create a 3D model of an electronic board and its components, then mesh it with Gmsh, solve the CFD problem in Elmersolver, and then do some postprocessing with Paraview. Our servers run Windows. The meshes used in solving these problems have up to 100K tets -- we're not looking for extreme accuracy but for something reasonably accurate and fast.
Lately we've started to create the 3D model of the system in OpenCascade and export it in STEP/BREP; we're also moving to more complex models. However, Gmsh is not working too well with these new STEP/BREP models and we're looking to replace it in the flow.
Can anyone recommend some free/commercial software that would work as a replacement for Gmsh? Basically, we have three requirements:
- the mesher should be entirely batch driven/scriptable (in our current setup, we just tell Gmsh to create finer mesh around some regions of interest -- e.g. power consuming components -- and then letting it apply it automatic meshing algorithms)
- the mesher should be able to input STEP or IGES or BREP formats (we'd prefer STEP/BREP, but it's not a dealbreaker)
- bonus points for being able to interface with Elmersolver, but we can write some converters
I've looked at Salome, but its Windows port is still beta and not entirely stable. Netgen and Tetgen are already incorporated in Gmsh, so they might not do the trick. I've spent some time on floTHERM's web page, but it's not clear whether it is scriptable or not.
Thanks,
Tibi
PS. Hope this is the right forum for this question.
tibich72 is offline   Reply With Quote
Old   May 28, 2011, 14:26
John Chawner
jchawner is on a distinguished road
Hello Tibi:
I work at Pointwise so you should treat this recommendation accordingly. But I think Pointwise will do what you need. It's scriptable and can be run in batch. It reads IGES (and we'll be releasing STEP import later this year). It doesn't have a native Elmersolver interface, but it does have a plugin SDK that you can use to customize your own Elmersolver interface. And it runs on Windows, Linux, and Mac. For more info see www.pointwise.com/pw.
Best of luck with your search.
John Chawner / jrc@pointwise.com / www.pointwise.com
Blog: http://blog.pointwise.com/
on Twitter: @jchawner
jchawner is offline   Reply With Quote
Old   June 1, 2011, 09:21
Tibi Chelcea
Hi John,
thanks for the recommendation. I was looking at Pointwise (Gridgen actually, but learned that Pointwise is the next generation of that) and I really liked the scripting capabilities. It's good to hear about it coming with an SDK so we can write our own exporter to Gmsh format (which is way simpler than Elmer's own).
Tibi
Originally Posted by jchawner View Post
Hello Tibi:
Old   June 4, 2011, 06:48
Vangelis Skaperdas
vangelis is on a distinguished road
Hello Tibi,
You could also have a look at ANSA.
I work at BETA CAE Systems S.A. which develops the code.
ANSA can read and write IGES, STEP and other neutral or native CAD files
and it also provides full meshing automation through the batch mesh tool.
No direct support for Elmersolver, but has numerous I/O format for
all major FEA and CFD codes.
I understand for example that Elmer can read Abaqus *.inp files
which can be written out by ANSA.
You can find information at
http://www.beta-cae.gr/
Best regards,
Vangelis
vangelis is offline   Reply With Quote
Old   June 4, 2011, 13:46
sail's Avatar
Vieri Abolaffio
sail is on a distinguished road
hi. i second the Pointwise suggestion. extremely scriptable and provide reasonably high quality tetrahedral meshes without too much manual tweaking.
I'm not sure how to interface it with other programs, so i can't comment on that.
probably your best guess would be to grab the demo licences of a few softwares and let the assistance help you to set up a simplified case. in this way you can get a feel of the workflow and the easyness of implementing the scripting capabilities in an automated fashion.
sail is offline   Reply With Quote
Old   June 8, 2011, 16:08
Elena Cortin
eleazar is on a distinguished road
For sure Pointwise is the leader ! ! ! !
We test it in InterFEA and we found out that it is top for CFD mesh.
Of course there are other solutions as well, but if you need a leader then Pointwise is your way to go
eleazar is offline   Reply With Quote
Old   June 9, 2011, 10:49
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Grid pro is extra ordinary. You will forget about any other software
Far is offline   Reply With Quote
Old   June 9, 2011, 10:56
Far
Sijal
Following is the list according to simplicity, robustness and quality of mesh
1. Grid Pro (easy to use, robust and very high quality mesh, blocking topology helps to mesh similar geometries with minutes )
2. ICEM CFD ( Hard to learn, Robust, high quality mesh, blocking topology helps to mesh similar geometries with minutes)
3. GridGen (simple to use : in fact very easy to use, robust, good quality mesh, manual work for mesh creation or have to write the scripts which may not work when geometry is not too similar)
It is also to be noted gridpro produces orthogonal mesh every time even without telling you. On the other hand ICEM CFD and Gridgen's eliptic solver is not good and may crash if meshing is complex. Just log on to grid pro website and ask them for evaluation version
Old   June 9, 2011, 11:24
Elena Cortin
Grid pro is also a very good solution, i will say that Far has right on that.
So as you unterstant Pointwise and Gridpro are ok for you
elmer, gmsh, mesh generation, software
Hexahedral Mesh Generation software makotohonda Main CFD Forum 1 July 14, 2010 00:04
Mesh Generation and CAD software MechE Main CFD Forum 2 May 15, 2010 15:18
CFD Software Recommendation 1150GSA Main CFD Forum 3 September 2, 2009 15:46
Mesh Generation Software TJ Main CFD Forum 1 February 6, 2007 10:18
Grid generation software Roued Main CFD Forum 1 November 22, 2001 05:26
