June 2, 2011, 19:44 |
C-Grid Boundary Conditions
Anonymous
Rep Power: 15 |
I am using a C-grid from here to analyze the NACA 0012 airfoil using Cradle's SC/Tetra. I am having some trouble setting the boundary conditions. What BCs should I use? For what I have already tried, some regions of the grid develop a very high pressure and others have a very low pressure. (This only happens when the angle of attack is non-zero, and in case it matters, I am simulating the angle of attack by varying the inflow direction).
I hope somebody can help me! Thanks in advance. P.S. I'm obviously new to this forum and hope to become more active once my work gets more difficult. |
June 6, 2011, 22:18 |
Anonymous
Rep Power: 15 |
So far, I have tried making the entire circular portion of the C-grid inflow and the rest a static pressure of 0, making the entire grid natural inflow/outflow and beginning with an initial condition which contained the velocity I wanted, and several other variations of the theme.
Could somebody please help me? |
June 6, 2011, 23:59 |
Martin Hegedus
Rep Power: 19 |
I'm not familiar with Cradle's SC/Tetra. If the code is compressible, you should use a characteristic (Riemann) boundary condition.
June 7, 2011, 15:58 |
Anonymous
Rep Power: 15 |
Is the Riemann BC the same as Natural Inflow/Outflow? This is what I believe, based on the small amount of literature that I actually understand.
Also, where should the Riemann BC be applied? I presume I also need in inlet, and where should that be? |
June 7, 2011, 18:21 |
Anonymous
Rep Power: 15 |
I'm not sure what you mean. My question is basically: "What BCs should I use for this?"
June 10, 2011, 16:58 |
#6 | |
Martin Hegedus
Rep Power: 19 |
http://turbmodels.larc.nasa.gov/naca0012_val.html Not sure what a "Natural" Inflow/Outflow B.C. is. I'm totally guessing that the idea is the same, but meant for an incompressible solver. Is your solution methodology incompressible? |
June 10, 2011, 17:49 |
Anonymous
Rep Power: 15 |
Yes, my simulation is incompressible. Natural inflow outflow is a BC in which the air can freely move out and into the domain.
mesh file for flow over a circular cylinder | Ardalan | Main CFD Forum | 7 | December 15, 2020 13:06 |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
Proper Pressure Boundary Conditions for Buoyant Flow | mchurchf | OpenFOAM | 0 | March 25, 2010 12:16 |
Error near boundary layer as 1st grid decrease | CF | Main CFD Forum | 3 | October 3, 2007 10:21 |
boundary conditions on MAC grid | merrouche | Main CFD Forum | 0 | August 24, 2003 14:49 |
