Coriolis Correction
Old   June 13, 2011, 00:10
Default Coriolis Correction
Felipe Hernandez
Petrov is on a distinguished road
So I want to simulate a rectangle falling through a fluid. (2d) I am going to start the rectangle with a zero initial velocity, and then as gravity acts on it, it will accelerate (which will be simulated by adding a force to the fluid, since I am in the reference frame of the rectangle), and the velocity will increase. At each timestep, I will integrate the force from the pressure (neglecting viscous terms) to find the force on the rectangle and the torque. Then I will update the angular velocity and velocity, etc..
For a given angular velocity and acceleration, I will have to add some correction force because I am in a non-inertial reference frame. How do I find the force? Do I need to change the mass matrix? (I have seen this done, but I'm not sure if it applies in this case)
Petrov is offline   Reply With Quote
Old   June 13, 2011, 12:31
cfdnewbie
cfdnewbie is on a distinguished road
Hello Petrov,
just a quick question for clarification:
you say you are simulating a rectangle falling through a flow field.... however, if you add the gravitational force to the fluid (not the rectangle), your flow will be accelerated downwards, while the rectangle stays in place....so in terms of the rectangle, it will not fall, it will rise up....
Or am I mistaken?
cheers :=)
newbie
cfdnewbie is offline   Reply With Quote
Old   June 13, 2011, 17:02
Felipe Hernandez
Oh, right!
The gravity goes on the object... and the fluid too. That's how real life works, no?
And I figured out the corrections required.. it comes from:
http://en.wikipedia.org/wiki/Rotating_reference_frame
Old   June 14, 2011, 05:09
cfdnewbie
Originally Posted by Petrov View Post
Oh, right!
Yeah, hopefully so
cheers!
Floating point exception error Alan OpenFOAM Running, Solving & CFD 11 July 1, 2021 21:51
curvature correction term, material derivative of a tensor volker OpenFOAM Programming & Development 7 June 3, 2010 08:08
Pressure correction problem richard_larson OpenFOAM Running, Solving & CFD 8 October 30, 2008 08:48
mass flux correction at outflow boundaries Subhra Datta Main CFD Forum 2 November 24, 2003 13:11
Pressure correction question - Please help! Barry Main CFD Forum 1 February 5, 2003 00:27
