Difficulties with Cd agreement!
Like Tree1Likes
  • 1 Post By Martin Hegedus
Old   July 13, 2011, 06:45
Default Difficulties with Cd agreement!
A.D.E is on a distinguished road
I am currently having difficulties obtaining a reasonable agreement for Cd between experimental and numerical results (Re approximately 1 million).
The numerical analysis is 2d and in the experimental procedure end-plates are used to achieve similar effect. The results are corrected for interference blockade etc!!! Does anyone know any reasons for the big difference obtained in Cd (more than 40%)? Is there anything in the published literature describing similar disagreement??
The values of Cl agree within 5%.
I would be grateful for any comments.
Sincerely,
A.D.E
A.D.E is offline   Reply With Quote
Old   July 13, 2011, 11:15
Naimish Harpal (MS Aerospace Engr)
naimishharpal is on a distinguished road
Which turbulence models are you using for this analysis? Make sure all your residuals are well converged below three magnitude. BTW, do you have enough mesh resolution in boundary layer as well as in wake region?
- NHarpal (www.cfdmax.com)
naimishharpal is offline   Reply With Quote
Old   July 13, 2011, 11:56
I am using K-w SST with y+ <1. My grid is clustered close to the airfoil and wake with more than 20 points in the boundary layer! My residuals drop 5 orders of magnitude and there is no change thereafter.
Old   July 13, 2011, 14:22
Martin Hegedus
Martin Hegedus is on a distinguished road
At what angle of attack is the difference of 40% and was the test tripped or untripped? Is your answer high or low? Is the problem incompressible or compressible? Can you describe your cross section a little? Is it an airfoil? Is it a cylinder? Can you give a reference for the experimental data?
You mentioned interference blockage. Why was the data corrected for that? I associate that with high subsonic/transonic issues. Or, when the wind tunnel has slots, even at low subsonic speeds. I don't recall coming across that for low subsonic flows with solid wind tunnel walls.
cfd_newbie likes this.
Martin Hegedus is offline   Reply With Quote
[ICEM] Meshing difficulties (Hexa meshing, O-Grid, etc.). Even possible to be resolved? JasonLam ANSYS Meshing & Geometry 0 April 19, 2011 20:08
Convergence Difficulties sarath CFX 2 August 21, 2006 08:35
CAD difficulties Carlos Saraiva Siemens 1 January 9, 2003 11:09
Modeling Difficulties using Pro-Star satish Siemens 0 February 29, 2000 06:12
Difficulties in solving a high Reynolds number Flow? wowakai Main CFD Forum 10 December 29, 1998 13:46
