boundary condition
Old   May 11, 2005, 06:40
Default boundary condition
Steve
I am trying to add a subroutine to a program which is a NS code using CV scheme. This sunroutine applies a specific boundary condition; as an example, it is supposed to change the velocities, pressure, and energy at a crossection at a position in the middle of a simple pipe, ie x=L/2, so for this example, 2 blocks is defined for the code. Problem is this sunroutine makes the code totally unstable, no convergence. I know based on this general info it is hard to say anything, but if there something that might be any help, please let me know.
Steve
Old   May 12, 2005, 12:38
Default Re: boundary condition
Steve
That's interesting that nobody made any comments on this!
Old   May 12, 2005, 13:02
noName
Are you solving for a steady solution? Or are you solving for a transient impulse response to these boundary conditions? Is there an analytic solution to such an impulse-type problem (e.g. exponential decay, similarity)?
Old   May 13, 2005, 08:13
Steve
Thanks for the response. I am solving for a steady solution, and at the moment I am running the code for a very simple case which is a cylindar with 2 blocks (the code is Multi-block). I am applying this boundary condition right at the common patch between the blocks.
What do you think?
Steve
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
Boundary Conditions Thomas P. Abraham Main CFD Forum 20 July 7, 2013 05:05
Setting outlet Pressure boundary condition using CAFFA code Mukund Pondkule Main CFD Forum 0 March 16, 2011 03:23
How exactly the "pressure outlet" bdry condition compute properties on the boundary? yating9901 FLUENT 3 June 28, 2010 12:26
How to set boundary condition in Fluent for the fo Peiyong FLUENT 1 November 10, 2006 11:44
