What is the Difference between Re=0 and Re=0.01 in Simulation of Viscoelastic Flow |
August 16, 2011, 10:12 |
Xingyuan Chen
I have a question for quite a long time. When people simulate viscoelastic flow, they usually do the simulation at Reynolds Number Re=0, in order to simulate the creeping flow. However there is no physical meaning for Re=0, except that the velocity is 0. But when the velocity is 0 then actually there is no 'Flow'. So why people simulate Re=0? Why not do the simulation for Re=0.01 or smaller instead of Re=0? Is there great difference between the results of Re=0 and Re=0.01? Thanks for your reply in advance! |
August 16, 2011, 10:26 |
Xingyuan Chen
BTW, when people simulate the case for Re=0, they just neglect the convective term in the momentum eqn.
August 17, 2011, 03:11 |
Xingyuan Chen
one difference is, when we consider the elastic number E=Wi/Re, where Wi is the Weissenberg number, then Re=0 and Re=0.01 are great different. But the problem is the elastic number can be also calculated by E= viscosity*relaxation time/(density*length*length).
August 18, 2011, 04:43 |
Xingyuan Chen
still need help
thanks |
August 9, 2012, 05:40 |
Amin Shariat KHah
some models can't be used for Re=0 or Wi=0 because of being this numbers in denominator.
after this, Re=.000001 is creeping flow and in viscoelastic viscous forces ( they are dominant in creep flow even for newtonian) are very important. |
November 28, 2012, 12:14 |
Xingyuan Chen
Could you please give me some examples that can not be used for Re=0?
November 28, 2012, 16:04 |
Filippo Maria Denaro
Rep Power: 71 |
