May 16, 2005, 17:53 |
Supersonic nozzle
Dear CFD people:
Is it possible to obtain uniform, isentropic, shock free flow through a minimum length nozzle (MLN), (the expansion section is eliminated) ? I believe it is possible but.. My question is: If it is possible to obtain uniform, isentropic, shock free flow through MLN, why people want to design a long supersonic nozzle with gently curved expansion section. Any comment is appreciated Thank you Danny |
May 16, 2005, 18:29 |
Re: Supersonic nozzle
Theoretically, yes it's possible, neglecting viscous effects.
I think there are some practical issues with the expansion region. With the expansion concentrated on a single point (or curve), the wall of a MLN usually has a sharp edge, right at the throat, around which the flow accelerates from Mach 1 to the maximum Mach number. One of the effects of viscosity could be flow separation at that edge. I am not sure if this is a big issue. It might not be, because of the acceleration. Another problem is heat. In practice a perfectly sharp expansion edge (even if you could manufacture it) will be hard to maintain because of friction. Eventually the edge will burn off. Anyhow, even though the exact MLN from inviscid theory may not be realistic, I am pretty sure that approximate MLNs (with very small expansion sections) are in use. How did you get the impression that this design is not used? |
May 18, 2005, 05:09 |
Theoritically yes applying the 1-D isentropic relations you can define a back pressure at which the flow from the nozzle is supersonic. But in reality the effect of the boundary layer interaction plays the spoilsport.
-H |
May 18, 2005, 13:52 |
To get supersonic flow, the nozzle must have a expansion section, to allow the flow the expand from sonic to supersonic. Then the expansion section have to be extended further (with careful design) to absorb the expansion waves, and finally get a "uniform" flow. The design of the expansion section is crucial to the flow quality.
If you say there's a MLN, then, yes, there should be one based on inviscid assumption. Hope this answers your question. Pete |
May 19, 2005, 10:38 |
Thank you all for the responses.
Danny |
April 14, 2009, 13:14 |
Axisymmetric Nozzle contour MOC
Logan Myers
Does anybody have a Matlab code for MOC contour design of an axisymmetric supersonic (Mach 2) nozzle they could send/sell me? Thanks in advance, Logan |
August 18, 2009, 04:14 |
#7 | |
Dileep Mathews
August 18, 2009, 17:24 |
Rich
Part of the issue is what you want to use the nozzle for. For a rocket nozzle, you want all of the gases moving the same direction (axially), to get maximum thrust. Early nozzles were conical (V-2, Redstone), and because some of the gases had a radial velocity component when leaving those nozzles, there was some degree of loss or inefficiency. If you wanted to, you could expand a gas through a simple orifice from high pressure directly to ambient, but the expansion fan at the exit will turn a great deal of the gas outward, radially, and hence, thrust is greatly reduced. To design a nozzle that directs all of the gases axially at the exit, the geometric angle of expansion at the throat can only be so large because the flow must be turned back onto itself without any shocks being generated. That takes a nozzle of finite length. Look for papers by G.V.R. Rao, who designed Rocketdyne's nozzles.
To my knowledge, the shortest nozzles ever developed are the "expansion-deflection" or "plug" nozzles. These were also developed by Rocketdyne (in fact they were even patented by Rocketdyne). Their Aerospike engine was just about as short as possible, and allowed for high efficiency even under highly off-design conditions. Pity NASA wasn't smart enough to employ those engines rather than the ones they ended up requiring for the Space Shuttle. But I digress... Rich |
March 7, 2011, 00:33 |
coding for supersonic 3d nozzle
DINESH KUMAR.T
Does anybody have a Matlab code for MOC contour design of an axisymmetric supersonic (Mach 2) nozzle they could send me @ dinesh_astronaut@yahoo.co.in Thanks in advance, DINESH |
April 15, 2017, 15:59 |
DNYANESHWAR BIRADAR
hello ,
I need a code to design axisymmetric supersonic nozzle if any one has it then please do send to - biradarradhe@gmail.com Regards D B |
C-D nozzle supersonic jet boundary | Gland | FLUENT | 4 | May 24, 2012 00:25 |
A supersonic combustion in a Laval nozzle | argeus | FLUENT | 0 | March 29, 2010 13:52 |
some questions for supersonic channel nozzle | goldenland | FLUENT | 2 | November 4, 2007 21:18 |
compressible flow in a counterflow nozzle | d.vamsidhar | FLUENT | 0 | November 24, 2005 01:45 |
jet structure at the end of a 2D supersonic nozzle | N Menon | CFX | 1 | November 7, 2001 08:04 |
