microchannel two phase flow with heat transfer
Old   September 24, 2011, 04:28
Default microchannel two phase flow with heat transfer
mkj
Mrinal Jagirdar
mkj is on a distinguished road
I am new to CFD software. Which software (Fluent, CFX or Openfoam) would you recommend for simulation of two phase flow (water and steam) with heat transfer in microchannel? I am thinking of using the VOF or the Level-set approach.
Instead of software, do you think coding might be better? Any other approach that is worth considering?
Thanks in advance,
Sincerely,
MKJ
mkj is offline   Reply With Quote
Old   September 27, 2011, 11:17
Default Microscale HT
CFDtoy
CFDtoy is on a distinguished road
At the micro level, capillary effects are much higher compared to convection scales. Use of VOF approach is preferred to get the bubble dynamics (injected into the channels) such as coagulation, stretching, deformation etc.
To simulate microchannel flows, your VOF scheme should be robust and very stable. Contact angle dynamics should also be included - to account for hydrophilic and phobic surfaces.
Flow3D, StarCCM, ANSYS - all can do this. No problem.
Writing your own code - well, why not use openFoam (as is) with its inbuilt VOF solver.
Read a lot of literature on the settings and BCs to impose.
Good luck.
/CFDtoy
Thanks in advance,
Sincerely,
MKJ
CFDtoy
CFDtoy is offline   Reply With Quote
Old   September 27, 2011, 21:49
mkj
Mrinal Jagirdar
Thank you CFDtoy.
Regards,
Mrinal
Heat Transfer Coefficient in Compressible Flow 3D turbine cascade Karkoura CFX 0 March 10, 2011 15:35
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
heat transfer probs by transonic flow Josh_Blue FLUENT 8 March 21, 2010 05:31
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 22:53
How can I increase Heat Transfer at Domain Interf? B.Simon CFX 3 October 28, 2008 18:53
