How to get the velocity field from the pressure field
Old   November 28, 2011, 05:25
Default How to get the velocity field from the pressure field
Hermano is on a distinguished road
I calculated the pressure field (in 2D) of air flowing through a graphite (porous material) using the finite difference method. Because I want to visualise the streamlines of the flow in the graphite I need to calculate first the velocity field.
My question is: How can I calculate the velocity field (in 2D) if the pressure field is known ?
Hermano is offline   Reply With Quote
Old   November 28, 2011, 12:18
truffaldino's Avatar
truffaldino is on a distinguished road
For quasistationary flows in porous medium one uses Darcy law, where velocity is proportional to the pressure gradient. If it is your case, just take gradient of the pressure.
truffaldino is offline   Reply With Quote
Old   November 29, 2011, 08:32
Andrew
mettler is on a distinguished road
you should get plugged flow..
you should use Brinkman-Forchheimer-extended Darcy equation to get the flow field. A lot of research has been done on this, and you can find numerous journal papers written about it..
good luck
mettler is offline   Reply With Quote
problems after decomposing for running alessio.nz OpenFOAM 7 March 5, 2021 04:49
Channel flow: Inlet pressure AND uniform velocity? frmap1 Main CFD Forum 0 April 15, 2010 10:32
Pressure field in atmosphere Luc3er FLUENT 0 November 9, 2009 07:07
Velocity in Porous medium : HELP! HELP! HELP! Kali Sanjay Phoenics 0 November 6, 2006 06:10
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
