CFX4.2 multi-fluid model
Old   June 28, 1999, 04:31
Default CFX4.2 multi-fluid model
wan xiaotao
I have two questiona about the CFX multifluid model: 1. In the CFX multi-fluid model,the convection term in the momentum equation is
div(ra(¦ÑaUaUa-¦Ìagrad(Ua)))
Clearly the viscosity ¦Ìa is the value of single phase.If the concerned phase is gas or liquid ,there is no confusion.But if solid kinetic model is used ,is there a single phase viscosity value? For example,one use the Gidaspow¡¯s theory to calculate the ¦Ìs,the ¦Ìs is the single phase value just analogous to gas phase or it has included the effect of phase fraction ra. 2. In the gas phase,some term in the shear stress is absorbed in the pressure. This term is (2/3¦Ì-¦Î)div(U).If the gas phase is incompressible in single phase,this term is equal to 0. Can the single phase incompressible conception be extend to multiphase model,and just set this term and the similar term in solid phase to 0.
best regards,
Wan xiaotao
Use of k-epsilon and k-omega Models Jade M Main CFD Forum 40 January 27, 2023 07:18
about Subgrid-scale model impecca OpenFOAM Running, Solving & CFD 4 December 20, 2013 10:36
using interface with Euler multi phase model karimi FLUENT 0 May 22, 2011 02:46
using interface with Euler multi phase model karimi Main CFD Forum 0 May 22, 2011 02:39
Using UDF to model bubble growing in a Fluid Daniel Ofori FLUENT 0 September 6, 2006 16:44
