Crank-Nicolson technique for Conservation form of equations
Old   June 29, 1999, 08:16
Default Crank-Nicolson technique for Conservation form of equations
Yogesh Talekar
Can some body tell me whether Conservation form of equations are solvable by Crank-Nicolson technique. Is there anything in the literature
Old   July 1, 1999, 09:45
Default Re: Crank-Nicolson technique for Conservation form of equations
Steven M Jachec
I have only seen C-N methods used to numerically solve parabolic PDEs.....do your governing equations fit this type of PDE. If so, you may be able to use C-N.
Steven
Old   July 20, 1999, 01:45
Abhijit Tilak
hello yogesh,
take a look at the book Numerical Heat Transfer and Fluid Flow by S.V.Patankar , Hemisphere Publishing 1980 ( 2nd ed. i suppose). He uses finite volume based finite difference method which is conservative however the method you are talking about is used to solve problems that are of marching type. ie one of the coordinates is a one - way coordinate, ie here it's the time. the equation has to be essentially a parabolic partial diff. equn. is that ok? bye
Delta form of Heat, Euler and NS equations RameshK Main CFD Forum 3 May 30, 2012 10:41
natural convection equations in non-dimensional form Ehsan Khalili FLUENT 7 April 29, 2012 21:06
Crank Nicolson. ! Main CFD Forum 0 September 5, 2005 12:52
strong conservation form of eulers equations Dahyalal Bhate Main CFD Forum 0 September 5, 2002 18:22
Equations in full form Mark Render Main CFD Forum 3 June 20, 2000 15:05
