3D sphere flow
Old   August 8, 2005, 09:49
Default 3D sphere flow
MH Kim
Hi, I'm calculating 3D viscous imcompressible flow of sphere using vortex method. I know that flow are axi-symmetric below Reynols number 200. But I get asymmetrical flow result at Reynolds number 50. Here I do not consider stretching term. So I'm wondering that asymmetrical flow result happen because i do not consider stretching. If I put stretching term into calculation, Will flow are axi-symmetric? Thank you for reading
Old   August 8, 2005, 17:06
Default Re: 3D sphere flow
Adrin Gharakhani
The stretch term in that low Reynolds number range is essentially zero anyway. So putting it explicitly equal to zero will not change the flow characteristics. Since the particles are undoubtedly distributed non-uniformly, there will be a "degree" of asymmetry. It is not clear from your message how asymmetric your flow is, 0.1%, 1%, 10%, ... off the symmetry?
The details of your implementation are very important. You need to explain how you're generating vorticity, how you're accounting for diffusion, and how you're evaluating the velocity field. Asymmetry could also develop due to lack of temporal/spatial resolution.
I have simulated flow over a sphere with our vortex code, and it is, for all practical purposes, symmetric up to the limit for that regime
Adrin Gharakhani
flow over sphere senthil Main CFD Forum 2 January 30, 2010 13:04
Flow past a sphere Fabio FLUENT 23 December 18, 2009 15:32
flow across sphere at Re=10,000 raheelrasool Main CFD Forum 3 April 19, 2009 22:31
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 05:44
Modeling diffusion of cell (sphere) under flow Shel Main CFD Forum 0 August 22, 2005 15:26
