Most common ODE solver
Old   February 3, 2012, 09:02
Default Most common ODE solver
Nereus
Nereus is on a distinguished road
It's my understanding that the method of lines is quite commonly used in CFD. What is the most common ODE solver used with this approach? For example, LSODA, VODE, or simply 4th order Runge-Kutta?
Nereus is offline   Reply With Quote
Old   February 3, 2012, 09:12
cfdnewbie
cfdnewbie is on a distinguished road
from my experience, RK4 is high up on the list!
cfdnewbie is offline   Reply With Quote
Old   February 3, 2012, 14:11
Sixkillers is on a distinguished road
It also depends on solved equations. If a problem is stiff, implicit numerical methods are more suitable for that task. For non-stiff problems Dorman-Prince method is the first shot integrator in many numerical solvers.
Sixkillers is offline   Reply With Quote
Old   February 3, 2012, 17:56
leflix is on a distinguished road
Yes I agree with cfdnewbie. RK4 is known to be the most accurate method (if you exclude RK5, RK6 etc....)
But if you plan to use it to solve Navier-Stokes equations in an explicit way, RK4 is quite expensive in CPU time and storage. A special RK3 method has been specifically designed to lower that cost.
leflix is offline   Reply With Quote
Old   February 3, 2012, 18:05
Dormand-Prince method is linked to RK method familly and seems to be more expensive than RK4. check this link for a gpl subroutine using this method.
http://www.unige.ch/~hairer/prog/nonstiff/dopri5.f
RK4 can be coded with 20 lines !!!
ODE solver coefficients mrangitschdowcom OpenFOAM Running, Solving & CFD 2 August 18, 2013 22:16
Working directory via command line Luiz CFX 4 March 6, 2011 20:02
Problem implementing CVODE ODE solver markusrehm OpenFOAM 20 October 13, 2010 17:02
Creating New Solver: For particle-laden compressible jets sankarv OpenFOAM 0 April 4, 2010 18:06
why the solver reject it? Anyone with experience? bearcat CFX 6 April 28, 2008 14:08
