CFD modelling of flow in flexible pipes
Old   February 7, 2012, 10:45
Default CFD modelling of flow in flexible pipes
Matthew
muntypro is on a distinguished road
Hello all, I'm new to this forum and joined since I have a CFD challenge.
I need to model the dynamic flow in flexible pipes and a quick google did not throw up any related papers, but I'm sure there are some.
The typical environment is a flat hose, like a fire hose, that is inflated by water pressure. I can't claim to know much about CFD applications since s/w has changed drastically since I did my degree in Mech Eng.
Can anyone indicate what package would be best used for this please and why? I'm familiar with Matlab/Simulink but this is a whole league different to my expertise. Is there anyone in the forum who wants to do some freelance work, since I can guarantee it will be more time and cost efficient that me buying/learning how to use a recommended package?
Q's, advice & comments much appreciated. Thanks.
muntypro is offline   Reply With Quote
Old   February 9, 2012, 13:38
rmh26 is on a distinguished road
Charles Peskin and Oliver Jensen have done a lot of work in this field. I'm not sure if any commercial software can handle this all that accuratley. You might be able to get some of Peskin's codes online. What is the nature of this research?
rmh26 is offline   Reply With Quote
Old   March 9, 2012, 11:41
Matthew
Thanks for the advice and sorry for not replying for a month! I got in touch with Charles and got some further advice. The nature of the research is to model the fluid dynamics and elastometric wall properties of a long fire-like hose when used for lifting heavy equipment (similar to airbags used in place of jacks or hyrdaulic equipment at accidents).
Old   March 12, 2012, 21:17
Do you need to do dynamic modeling (looking at the initial inflation) or just static cases?
Old   March 13, 2012, 04:16
Matthew
Yes, I do need to do dynamic modelling. Initially the hose will be flat and a constant evenly distributed pressure applied along its length. When water is admitted from one end it will inflate the hose to a non-circular profile, and progress along the length.
I think full inflation will only occur when the whole length has some water in it (let's call this 'lift-off' time). A certain time later, depending of the delivery pump pressure and flow rate the hose will have an approximately circular shape, depending on the constant external side pressure applied.
The dynamic part I'm most interested in is the initial phase where fluid runs along the length before lift off. Let's assume the hose is inelastic if it's made of an impregnated woven glass fibre cloth.
Also let's assume the external body applying pressure is non-rigid (eg sacks of sand or ballast) so lifting at one end is not influenced by the other.
Is there an applied external pressure where the fluid will not flow along the length and instead lift the weight and form an approximately circular profile that will then work its way along the length?
(I guess another example of this is the inflation of balloons. Standard profile ones inflate evenly in all directions whilst long ones inflate along their length -handy for making into party shapes!. This is highly influenced by the elastic properties in circumferential and longitudinal directions, and the aspect ratio.)
dynamic mesh, elastic wall, flexible, pipe flow, pressure coefficient
Fanno Rayleigh flow in pipes Dave Main CFD Forum 4 August 1, 2021 04:52
CFD Salary CFD Main CFD Forum 17 January 3, 2017 17:09
Where do we go from here? CFD in 2001 John C. Chien Main CFD Forum 36 January 24, 2001 21:10
ASME CFD Symposium, Atlanta, July 2001 Chris R. Kleijn Main CFD Forum 0 September 13, 2000 04:48
Troubles modelling flow through a grid Hans Klaufus CFX 1 June 28, 2000 16:43
