Numerical oscillations Roe solver shallow water equations
Old   February 21, 2012, 05:31
Default Numerical oscillations Roe solver shallow water equations
RicardoGoncalves is on a distinguished road
Dear all,
I am using a finite volume shallow water model which uses the Roe Riemann solver. The scheme is only of 1st order and is applied to a structured rectangular grid, but I am still getting some nasty oscillations when simulating flows over a rather complex topography.
As far as I understand, this first order scheme should be stable (although highly diffusive); so my first guess for the cause of the oscillations is the treatment of the source terms (in this case bed topography).
Does anyone have a better guess/solution for this problem?
Thanks
RicardoGoncalves is offline   Reply With Quote
Old   March 5, 2012, 03:03
Fabian82 is on a distinguished road
Dear RicardoGoncalves
Your problem is most likely be related to the source term. When the discretization errors of the Roe solver and the source term are not compatible, errors and noise may grow in time without any physical forcing. Your solver will therefore not be able to maintain a 'quiet' water state over a complex topography. A possible solution to this problem are so-called 'well-balanced schemes' which can be found in numerous formulations in literature, e.g. by modifying the interface reconstruction or by upwinding the source term at the interfaces.
Best wishes
Fabian
Fabian82 is offline   Reply With Quote
finite volume, oscillation, riemann, roe, shallow water
Numerical oscillations in LES due to mesh refinement Soder OpenFOAM 0 June 14, 2011 10:10
Vorticity in inviscid shallow water equations sonsiest Main CFD Forum 0 June 7, 2011 14:10
roe solver with entropy fix mehdi Main CFD Forum 1 February 26, 2006 05:36
Navier-stokes equations and iterative solver?? wuliang Main CFD Forum 2 January 13, 2003 22:28
multi-layer shallow water or Sigma coordinate? Hadian Main CFD Forum 0 August 8, 2002 09:53
