Odd residual behaviour for Two Layer K Epsilon
Old   February 28, 2012, 05:01
Default Odd residual behaviour for Two Layer K Epsilon
David Van Cauwenberge
dvcauwe is on a distinguished road
I am currently pursuing my Master's thesis using CFD-ACE to simulate flow inside finned tubes. As results for realizable K-epsilon with two-layer wall function were way off, I'm currently using the standard "Two Layer K Epsilon" turbulence model.
The results are fine but my residuals always follow a similar behaviour:
After normal behaviour for the first 100-500 iterations, the kinetic energy and afterwards the dissipation rate residuals start rising and fluctuating greatly while the others will no longer drop. Anyone have an idea what might be causing this?
Many thanks in advance.
dvcauwe is offline   Reply With Quote
Old   March 7, 2012, 05:47
cdf_user is on a distinguished road
The residuals fluctuate when the flow encounters the fins. Try similar geometry without fins and you wont see the fluctuations. You can tighten the relaxation factors to decrease the fluctuations. The fluctuations are not harmful. They only delay convergence.
cdf_user is offline   Reply With Quote
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 13:40
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
Unknown error sivakumar OpenFOAM Pre-Processing 9 September 9, 2008 12:53
