March 14, 2012, 08:07 |
Buoyancy driven flow
Hamid
Hi everybody,
I'm going to solve a simple flow over flat plate and I'm going to have heat equation and buoyancy effects in my flow. My domain size is 1500(height)x6000x6000 [m] and my first grid center is located 0.03 away from the ground. I have periodic lateral BC, Symmetry top BC and no-slip wall BC. I can simulate the flow when I have a neutral case but with temperature it diverges very fast. Do you have any idea what could be wrong? Note that with this size Grashof number becomes enormous, but I don't know if that's the problem. I appreciate all your suggestions |
March 14, 2012, 13:07 |
How about first trying with reducing your URF and making your solution more stable.
March 14, 2012, 13:26 |
Andrew
Rep Power: 18 |
it sounds like a grid problem. Especially with buoyancy driven flow. Most of the interaction will be close to the wall, so you need a good grid in that region. I am assuming your plate is vertical and not horizontal.
March 15, 2012, 07:02 |
Filippo Maria Denaro
Rep Power: 71 |
maybe, it can be a case of numerical instability due to the high Gr number...
March 15, 2012, 09:03 |
Hamid
March 15, 2012, 09:11 |
#6 | |
Hamid
Now, even the temperature equation works fine but only if I disregard the gravitation. |
March 15, 2012, 09:13 |
Hamid
I might also take a look at the block communications (it's a multi-block structured code I'm using) to see if something goes strange ...
March 15, 2012, 09:15 |
Hamid
mmm, yeah, meybe, since it scales up as L^3 (L being characteristic length scale) ... but isn't it what normally happens? I mean I'm just simulating a small part of the real atmosphere with temperature stratification ...
March 19, 2012, 10:39 |
problem partly solved, not sure if it's true ...
Hamid
Hi again,
regarding the issue with buoyancy driven flow, I tried to decouple temperature and momentum equations completely i.e. after the solution for pressure and velocities converge, I solve the heat equation and most importantly "add the buoyancy contributions". Seems it solved the issue ... I know it's a general practice to treat the heat equation like this (quasi-steady) but not sure if it's true when you have buoyancy? since buoyant force affects the flow field directly and might make it inaccurate ... |
March 19, 2012, 10:56 |
#10 | |
Rep Power: 71 |
April 19, 2012, 04:46 |
show me by CFX
#11 | |
Safia
My problem is the same as yours. I have fluid flow with heat transfer and the buoyancy takes place through my model. Regards |
May 14, 2012, 23:56 |
#12 | |
Safia
thanks for your good thread.However, I'm still sad because I asked to show me how until I do it after 2 months!!..some guys do not care about the others. you will feel better whan youbecome helpful member |
buoyancy flow, divergence, grashof number |
2D Lid Driven Cavity Flow simulation using MATLAB | josephlm | Main CFD Forum | 4 | August 17, 2023 20:36 |
Flow meter Design | CD adapco Group Marketing | Siemens | 3 | June 21, 2011 08:33 |
is there any parallel code for the famous Lid Driven Cavity flow? | gholamghar | Main CFD Forum | 0 | August 1, 2010 01:55 |
steam flow in a pipe driven by a pressure gradient between inlet and outlet | SalvoCalvo | COMSOL | 0 | March 11, 2010 06:52 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 12:19 |
