Tecplot file converter for Paraview/OpenDX
Old   September 19, 2005, 06:35
Default Tecplot file converter for Paraview/OpenDX
Mason
Does anyone know if there is conversion utility that will convert Tecplot file format (specifically tecplot_ise) to import easily into OpenDX or Paraview?
Mason
Old   September 19, 2005, 09:37
Default Re: Tecplot file converter for Paraview/OpenDX
Renato N. Elias
I know that I'll answer with a stupid question, but
Do you have Ensight?
With Ensight you'll be able to open your Tecplot file and export Ensight case to read with Paraview.
Regards.
Renato N. Elias
Old   September 19, 2005, 12:25
Mason
No, I don't have Ensight. Is it open source? I will check this out although the .dat files that are created from DESSIS are not standard Tecplot files at all (they have a OEM relationship). Thanks for the hint though Renato.
Mason
1.7.x Environment Variables on Linux 10.04 rasma OpenFOAM Installation 9 July 30, 2010 04:43
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
[Gmsh] Compiling gmshFoam with OpenFOAM-1.5 BlGene OpenFOAM Meshing & Mesh Conversion 10 August 6, 2009 04:26
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
