large Reynolds
Old   September 22, 2005, 04:59
Default large Reynolds
Alf
I solve standard incompressible Navie-Stokes Equations on enough rough grid and where Re=10^5. Has the solution any physical sense? Or I necessarily should use any model of turbulence? I.e. may be laminar flow at Re=10^5? Thanks.
Old   September 22, 2005, 05:14
Default Re: large Reynolds
Davoche
It depends on what you are tryng to simulate. Under certain condition you could have a laminar flows at such Reynolds number... But If you are in a standard case ( for example classical channel flows with implicit roughness ) you Have to use a model for turbulence ( k epsilon , Large Eddy Simulation ) or a DNS ( Direct Numerical Simulation ) which will resolve the fine structures ( and not modelise them ).
Old   September 22, 2005, 05:15
Davoche
Sorry, forget the DNS at such a Reynolds Number...
Old   September 22, 2005, 06:56
diaw
Hi Alf,
What does your geometry look like?
If you have boundary-layer flow, using Rex, then perhaps the flow is 'just' laminar. If you have any boundary constraints then your Reynolds will drop. In that case you would be surley be missing something at Re~1e5.
Bejan tabulates & graphs this nicely.
What discretisation scheme are you using? What convection-stabilisation scheme do you use? Are you using a steady-solver, or transient?
diaw...
Old   September 22, 2005, 10:20
agg
Some approaches like MILES, make use of special numerical schemes and do not use turbulence models
Scaling the Reynolds stresses via UDF Markus FLUENT 1 November 11, 2022 12:44
New implemented algebraic Reynolds stress model volker OpenFOAM 13 October 21, 2013 00:01
Reynolds Stress Models Jade M Main CFD Forum 0 April 21, 2010 16:38
Reynolds Stress Boundary Conditions tstorm FLUENT 0 July 27, 2009 14:44
Reynolds stresses without velocity correlations? Phil Main CFD Forum 1 October 2, 2006 04:29
