CGNS fortran code compiling with intel visual fortran xe
Like Tree6Likes
  • 1 Post By dokeun
  • 5 Post By dokeun
Old   April 3, 2012, 11:26
Default CGNS fortran code compiling with intel visual fortran xe
Dokeun, Hwang
dokeun is on a distinguished road
Dear ...
I compiled cgnslib_3.1.3 using CMake-gui(ver 2.8.7) with generator 'visual studio 9 2008' and there were some options as follows.
I'd like to know what other Names unchecked in Value colume are
Should I check ENABLE_FORTRAN in order to use fortran code for my program?
However, when I did configure & generate with this option, I couldn't build "cgns.sln"
Should I check BUILD_CGNSTOOLS in order to use cgnstools?
Name __________________________________________________ Value
BUILD_CGNSTOOLS___________________________________ ___ □
CGNS_BUILD_SHARED_________________________________ ___v
CGNS_USE_SHARED___________________________________ ___v
CMAKE_BUILD_Type__________________________________ ____Release
CMAKE_INSTALL_PREFIX______________________________ ____C:/Program files/cgns
ENABLE_FORTRAN____________________________________ ____□
ENABLE_HDF5_______________________________________ ____□
ENABLE_LEGACY_____________________________________ ____□
ENABLE_LFS________________________________________ ____□
ENABLE_SCOPING____________________________________ ___□
ENABLE_TESTS______________________________________ ____□
With default option, I could build cgns.sln by MS visual studio and got some files as follows in debug folder
"cgns.idb, cgns.lib, cgns.pdb, cgnsdll.dll, cgnsdll.exp, cgnsdll.idb, cgnsdll.ilk, cgnsdll.lib, cgnsdll.pdb"
What should I do with these files in order to test fortran files described in CGNS User's Manual?
samurai_01 likes this.
dokeun is offline   Reply With Quote
Old   April 5, 2012, 21:01
Default got solved
Dokeun, Hwang
Hi there.
After few days of efforts, I somehow installed the library & cgnstools.
When I first tried to install it, I didn't even know what makefile, cmake mean.
And README and other explanation files included were not enough for me.
Even though this looks clumsy a little, it works.
So I'd like to share my experience hoping that it can be a help.
And I hope someone presents more refined solution.
PC environment is as follows..
OS : windows 7
Program : MS Visual Studio 2008, Intell Visual Fortran
[How to install cgns library and cgnstools]
1. Download lastest source file(ver. 3.1.3) from http://cgns.sourceforge.net/download.html
2. Download HDF5 from http://www.hdfgroup.org/HDF5/release...n5.html#obtain and install it.
=> I'm not sure if it is necessary but I followed an install guide in the cgns sources
=> I'm not sure waht you should install. But I choosed HDF5188-win32-static.zip
3. Download Tcl from http://www.activestate.com/activetcl/downloads and install it.
=> In my case, I installed it to c:\Program files\Tcl
=> Regist ...Tcl\include as include < environment variables
...Tcl\lib as lib < environment variables
4. Unzip cgnslib_3.1.3.tar. wherever you want
=>then some files and directories will be shown
5. Excute "Visual Studio 2008 Command Prompt" from Start>Miscrosoft Visual Stuio 2008>Visual Studio Tools
=>cmd won't work if you don't set path or something in environment configuration.
6. Go to the ...\src under the directory you unzipped cgnslib_3.1.3
=> ex) c:\Program files\CGNS\cgnslib_3.1.3\src>__
7. type
..\src>configure.bat -lfs -ifort -tcl [tcl directory] -install [install directory]
=> here, [tcl directory] is where the tcl is installed. ex)c:\Progra~1\Tcl
=> [install directory] is where a result will be installed. ex)c:\Progra~1\CGNS
=> Caution! There should not be any blanck when those directories are typed. Type "Progra~1" instead of "Program files".
8. type
..\src>nmake all
=> In my case two error messages were given but those didn't matter. I just typed this command one more.
9. type
..\src>namke install
=> Then 2 or 4 folders including files will be installed to [install directory]
=> If you have no problem, then there should be 4 directories.
include, bin, share, lib
=> In my case there were just 2 folders, include, lib. so I executed.
...src\sgnstools>cgconfig.bat
...src\sgnstools>nmake install
A. Regist following folders in MS Visual Studio>Tools>Options>Intel(r) VF>Compiler
...>CGNS>lib
...>CGNS>include
=> But, when I compiled fortran code from example codes, I had to include "..CGNS\lib\cgns.lib" as resource file in MS Visual IDE. Refer attached image.
B. Just execute batch files in the folder, ...CGNS>bin for cgnstools
Comparison between C/C++ and Fortran? rick Main CFD Forum 45 September 6, 2011 00:52
CFD Code with Fortran murat Main CFD Forum 0 October 11, 2009 17:05
Intel Fortran and CFX 11.0 Rogerio Fernandes Brito CFX 4 November 11, 2008 00:27
visual fortran Monica Main CFD Forum 1 August 28, 2004 20:45
Error when compiling user fortran Mads Bang CFX 1 October 8, 2002 11:47
