Home > Forums > Special Topics > Mesh Generation & Pre-Processing
prism mesh around spaceplane that cover vow shock
Old   December 4, 2014, 02:58
Default prism mesh around spaceplane that cover vow shock
Iligusk is on a distinguished road
Hi
I'd like to get advise to generate mesh around space plane.
I'm trying to calculate hypersonic flow field around the space plane (something like space shuttle) using unstructured mesh.
To get accurate heat transfer rate, I thought it's better to cover the vow shock by prism layer.
Because,tetra is not suitable for resolution of shock, and it's hard to adapt to shock.if it's covered by prism layer, it's easy to put shock surface between prism layer.
Is generate prism layer from surface until vow shock good idea?
or could you give me other method for unstructure mesh?
Actually, it was impossible to extrude surface mesh until vow shock when I used my Laboratory's old Gridgen and Pointwise.
so, I'm thiking to make program by myself using Boundary integral equation.
thank you
Iligusk is offline   Reply With Quote
prism, unstructured
Why Differences between tetrahedra polyhedra and prism mesh pipe flow computation with sonicLiquidFoam chnrdu OpenFOAM Running, Solving & CFD 5 May 7, 2018 03:23
[ICEM] Creation of hexa dominant mesh and prism layer gnuboard ANSYS Meshing & Geometry 7 January 11, 2018 04:13
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 09:03
