Home > Forums > Special Topics > Mesh Generation & Pre-Processing
what is the best strategy for dynamic mesh ?
Like Tree2Likes
  • 2 Post By al_th
Old   April 15, 2015, 04:53
Question what is the best strategy for dynamic mesh ?
logan
wolverine is on a distinguished road
i have been trying to create a mesh for dynamic boundary . like an oscillating wall . i always encounter negative volume error .
wolverine is offline   Reply With Quote
Old   June 5, 2015, 07:30
Al_th
al_th is on a distinguished road
Hi wolverine,
I guess the final solution will be dependant of what are the tools that you use, but I have worked on a similar problem (Oscillating wall).
I am using Salome to mesh my geometry
I am using Openfoam to solve both mesh motion and flow equations
Within Openfoam, I am using pimpleDyMFoam application with dynamicMotionSolverFVMesh
The problem I encountered that when the motion of the wall was too big, some of the cells of the mesh collapsed.
I found that there is some motion solver that are able to resolve topological changes (typically when a cell collapses, you have a change in the topology of your mesh), but in my case I had a lot of errors.
The solution I have found is the following :
- Define a python script to do the geometry and the meshing (Salome accepts python scripts)
- Initialise position of the wall
- Start the simulation until it crashes (the only reason my simulations crashes are because of cells that are either collapsing or extending too much).
- Look at the last position of the wall
- Remesh with the current wall position
- Map the result of your previous mesh to your new mesh.
- Restart simulation at the last timestep with the new mesh.
Everything is scripted in bash, and this is a little bit tiresome, but it works quite well at the end, and it is doing what was expected !
wolverine and scleakey like this.
al_th is offline   Reply With Quote
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 09:03
engrid -> save as .stl with boundarie codes Zymon enGrid 31 August 29, 2011 13:40
