Home > Forums > Special Topics > Mesh Generation & Pre-Processing
Boundary layer in Gmsh with OpenCASCADE
Old   June 13, 2017, 07:07
Default Boundary layer in Gmsh with OpenCASCADE
Malgorzata
chomikzimon is on a distinguished road
Dear All,
I am trying to create a boundary layer for a u-bend circular pipe. I have used the elements of OpenCASCADE, such as disk and wire; therefore, I cannot add a boundary layer through simple extrusion. I tried using Field[]=BoundaryLayer, but that also did not produce anything Could you please advise me on how to fix this issue? Please find my script below.
Thank you!
SetFactory("OpenCASCADE");
/* ** Choose general settings ** */
Mesh.CharacteristicLengthMin = 0.05;
Mesh.CharacteristicLengthMax = 0.05;
Geometry.NumSubEdges = 100; // nicer display of curve
General.Color.Text = Black;
Geometry.Color.Points = Purple;
General.Color.Background = White;
Mesh.Color.Points = {255,0,0};
//Mesh.Algorithm3D = 4;
//Mesh.Smoothing = 100;
//Mesh.Optimize=1;
//Mesh.OptimizeNetgen=1;
/* ** Define constants ** */
DefineConstant[
npts = {16, Name "Number of points in the bend"}
r = {0.38, Name "Bend radius"}
rd = {0.125, Name "Radius of the cross-section"}
mes = {1e-2, Name "Mesh element size"}
lh = {1.49, Name "Length of the horizontal section"}
lv1 = {0.74, Name "Length of the 1st vertical section"}
lv2 = {2.07, Name "Length of the 2nd vertical section"}];
/* ** Create the first elbow ** */
For i In {0:npts}
theta = i * 0.5 * Pi/npts;
Point(i + 1) = {r * Cos(-theta), r * Sin(-theta), 0, mes};
EndFor
nr[] += 1;
Spline(nr[0]) = {1: npts+1};
Wire(nr[0]) = {1};
Disk(nr[0]) = {0,-r,0, rd};
Rotate {{0, -r, 0}, {0, 0, 0}, Pi/2} {Surface{nr[0]};}
my_volumes[] += Extrude { Surface{nr[0]}; } Using Wire {nr[0]};//pipe
/* ** Translate and duplicate the end point to create the horizontal section ** */
my_new_points[] += Translate {-lh, 0, 0} { Duplicata{ Point{npts+1}; }};
nr[] += newreg;
Spline(nr[1]) = {npts + 1, my_new_points[0]};
Wire(nr[1]) = {nr[1]};
Disk(nr[1]) = {0, -r, 0, rd};
Rotate {{0, -r, 0}, {0, 0, 0}, Pi/2} {Surface{nr[1]};}
my_volumes[] += Extrude { Surface{nr[1]}; } Using Wire {nr[1]};
/* ** Create the second elbow ** */
p1 = newp;
For i In {0:npts}
Point(i + p1) = {-lh -r * Cos(-theta), r * Sin(-theta), 0, mes};
EndFor
p2 = newp;
nr[] += newreg;
Spline(nr[2]) = {p1: p2-1};
Wire(nr[2]) = {nr[2]};
Disk(nr[2]) = {-1.87, 0, 0, rd};
Rotate {{-(lh + r), 0, 0}, {0, 0, 0}, Pi/2} {Surface{nr[2]};}
my_volumes[] += Extrude { Surface{nr[2]}; } Using Wire {nr[2]};
/* ** Translate and duplicate a point to create the upstream vertical section ** */
my_new_points[] += Translate {0, lv1, 0} { Duplicata{ Point{p1}; }};
nr[] += newreg;
Spline(nr[3]) = {p1, my_new_points[1]};
Wire(nr[3]) = {nr[3]};
Disk(nr[3]) = {-(lh + r),0,0, rd};
Rotate {{-(lh + r), 0, 0}, {0, 0, 0}, Pi/2} {Surface{nr[3]};}
my_volumes[] += Extrude { Surface{nr[3]}; } Using Wire {nr[3]};
/* ** Translate and duplicate a point to create the downstream vertical section ** */
my_new_points[] += Translate {0, lv2, 0} { Duplicata{ Point{1}; }};
nr[] += newreg;
Spline(nr[4]) = {1, my_new_points[2]};
Wire(nr[4]) = {nr[4]};
Disk(nr[4]) = {r, 0, 0, rd};
Rotate {{0.38, 0, 0}, {0, 0, 0}, Pi/2} {Surface{nr[4]};}
my_volumes[] += Extrude { Surface{nr[4]}; } Using Wire {nr[4]};
//Printf("Surface id: %g", nr[0]);
Delete{ Surface{nr[]}; }
chomikzimon is offline   Reply With Quote
Old   October 5, 2017, 09:15
ahab is on a distinguished road
Hi chomikzimon,
I stumbled upon the very same problem and can't find a solution. I have been working on it for a while now. As I am additionally using boolean operators, I am also not able to work around the issue through using only functions that work with the SetFactory "built-in". Were you able to solve your problem? I would be very glad for any kind of help!
ahab is offline   Reply With Quote
Old   October 5, 2017, 09:20
Malgorzata
Unfortunately, I don't think there is an easy way to do it in Gmsh at the moment. I moved to Salome instead.
I am sorry for not being of much help.
Old   December 3, 2017, 07:50
Question Boundary in GMSH
Leonardo
Leoonardo is on a distinguished road
how can I make a duplicate mesh in the structure and not duplicate in the fluid in the GMSH?
Geometry is the cross section of the guitar, I'm having trouble putting just fluid in the sound hole of the guitar.
and I need the mesh to be triangular regular
between point(4) and point (5), it's the sound hole, and there I need it to be just fluid and the line(4) disappears.
help me please, i'm beginner of scientific research
msh code .geo
dim = 34;
gridsize = dim/4;
dim2 = 38.3;
gridsize2 = dim2/4;
dim3 = 48;
gridsize3 = dim3/4;
Point(1) = {0, 0, 0, gridsize};
Point(2) = {dim3 , 0, 0, gridsize3};
Point(3) = {dim3 , 10.5, 0, gridsize3};
Point(4) = {dim2, 10.5, 0, gridsize2};
Point(5) = {dim, 10.5, 0, gridsize};
Point(6) = {0, 10.5, 0, gridsize2};
Line(1) = {1, 2};
Line(2) = {2, 3};
Line(3) = {3, 4};
Line(4) = {4, 5};
Line(5) = {5, 6};
Line(6) = {6, 1};
Line Loop(1) = {6, 1, 2, 3, 4, 5};
Plane Surface(1) = {1};
Leoonardo is offline   Reply With Quote
[snappyHexMesh] snappyHexMesh Boundary Layer at Corner panpanzhong OpenFOAM Meshing & Mesh Conversion 5 July 3, 2018 05:53
Problem in setting Boundary Condition Madhatter92 CFX 12 January 12, 2016 04:39
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 06:20
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
[Gmsh] Default Faces on Boundary Layer axel OpenFOAM Meshing & Mesh Conversion 8 February 17, 2011 07:47
