Home > Forums > Special Topics > Mesh Generation & Pre-Processing
[GMSH] Incompatible surface in transfinite volume with 5 faces
Old   March 18, 2021, 11:25
Default [GMSH] Incompatible surface in transfinite volume with 5 faces
Rodolphe Vancoillie
rvanco is on a distinguished road
I'm trying to build a structured mesh on a "piece of cake" geometry (to compute CFD calculations with Code Saturne on a 2D domain and not the whole 3D cylinder). But when I compute the 3D mesh on gmsh, an error occurred due to an incompatible surface with the transfinite volume.
Here is the code :
// Gmsh project created on Thu Mar 18 15:13:30 2021
SetFactory("OpenCASCADE");
Point(1) = {0, 0, 0, 1.0};
Point(2) = {0.1, 0, 0, 1.0};
Point(3) = {0.099, 0.01, 0, 1.0};
Line(1) = {1, 3};
Line(2) = {3, 2};
Line(3) = {2, 1};
Curve Loop(1) = {1, 2, 3};
Plane Surface(1) = {1};
Extrude {0, 0, 0.2} {
Surface{1};
Physical Surface("Symmetry_planes", 10) = {4, 2};
Physical Surface("Adiabatic_wall", 11) = {3};
Physical Surface("Hot_wall", 12) = {1};
Physical Surface("Cold_wall", 13) = {5};
Transfinite Curve {4, 7, 5} = 10 Using Progression 1;
Transfinite Curve {9, 6, 3, 1} = 10 Using Progression 1;
Transfinite Curve {8, 2} = 3 Using Progression 1;
Transfinite Surface {4};
Transfinite Surface {2};
Transfinite Surface {5};
Transfinite Surface {3};
Transfinite Surface {1};
Recombine Surface {4, 2, 5, 3, 1};
Transfinite Volume{1} = {4, 1, 2, 3, 6, 5};
I am new with GMSH, I was using the Salome built-in geometry and mesh software but I've got issues to build hexahedron cells on such a geometry because there are only 3 faces and Salome ask for a minimum of 4 faces with hexahedron (if you know how to solve this problem, I'm really interested too)
Thanks for your help !
Rodolphe
rvanco is offline   Reply With Quote
error, gmsh, salome
[Gmsh] gmshToFoam generates patches with 0 faces and 0 points Simurgh OpenFOAM Meshing & Mesh Conversion 4 August 25, 2023 07:58
[Gmsh] "Perhaps you have not exported the 3D elements?" j_moulton OpenFOAM Meshing & Mesh Conversion 14 October 6, 2022 21:58
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
[snappyHexMesh] layer not added Rasmusiwersen OpenFOAM Meshing & Mesh Conversion 1 January 2, 2020 09:43
[snappyHexMesh] SHM is not extruding/adding Layers everywhere matthiasd OpenFOAM Meshing & Mesh Conversion 2 October 16, 2016 16:45
