[gmshToFoam] [checkMesh] Error high aspect ratio, ngetaive face area and cell volume |
March 26, 2021, 11:11 |
bintangwicaksono
Hello forum !
First of all I am new to Openfoam. I have a mesh using GMSH, extrude (to get 3D domain) and gmshToFoam. At first, its all looks nice until i do « checkMesh » and all of enjoyment dissapear. I have this following error Code:
***High aspect ratio cells found, Max aspect ratio: 3.35195e+155, number of cells 67 <<Writing 67 cells with high aspect ratio to set highAspectRatioCells ***Zero or negative face area detected. Minimum area: 0 <<Writing 137 zero area faces to set zeroAreaFaces ***Zero or negative cell volume detected. Minimum negative volume: 0, Number of negative volume cells: 67 <<Writing 67 zero volume cells to set zeroVolumeCells Mesh non-orthogonality Max: 90 average: 34.0927 ***Number of non-orthogonality errors: 37. <<Writing 37 non-orthogonal faces to set nonOrthoFaces Face pyramids OK. ***Max skewness = 1.78771e+154, 135 highly skew faces detected which may impair the quality of the results <<Writing 135 skew faces to set skewFaces Coupled point location match (average 0) OK. Failed 5 mesh checks. End |
July 10, 2023, 20:56 |
Nick Howlett
Rep Power: 4 |
I've recently had a similar issue and found that GMSH's Transfinite meshing with grading (for boundary layers, for example) caused such non-realistic results in checkMesh (by removing the grading checkMesh was happy).
If needing grading, perhaps use GMSH's boundaryLayer (Field) method. Details on the code needed: How to create a 2D boundary layer in gmsh? |
checkmesh error, checkmesh issue, gmshtofoam, high aspect ratio, negative cell volume |
Simulating fire in a tunnel | luca1992 | OpenFOAM | 14 | August 16, 2017 13:50 |
How to use "translation" in solidBodyMotionFunction in OpenFOAM | rupesh_w | OpenFOAM Running, Solving & CFD | 5 | August 16, 2016 04:27 |
[snappyHexMesh] sHM layer process keeps getting killed | MBttR | OpenFOAM Meshing & Mesh Conversion | 4 | August 15, 2016 03:21 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 05:42 |
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 05:50 |
