November 5, 2021, 12:42 |
Seakeeping Solver:Crashed
Akbar Bagus Darmawan
HI, I'm Akbar Bagus Darmawan from Ship Manufacture Engineering Poliwangi, Indonesia. i have a seakeeping project, but the solver is always crashed with following report below.
TIME STEP : 603 ME : 0.1055403E+02 ORDER 2 Face number 859248 badly oriented, block 1 Xf -0.1040615E+01 Yf 0.2454893E+01 Zf 0.5219857E+00 Face number 859288 badly oriented, block 1 Xf -0.1045083E+01 Yf 0.2497697E+01 Zf 0.5316862E+00 Face number 859302 badly oriented, block 1 Xf -0.1040949E+01 Yf 0.2541203E+01 Zf 0.5222630E+00 Face number 871128 badly oriented, block 1 Xf -0.8516029E-03 Yf 0.2013228E-01 Zf 0.2057374E+01 Face number 871146 badly oriented, block 1 Xf 0.3326028E-01 Yf 0.4939139E-01 Zf 0.2051964E+01 Face number 923002 badly oriented, block 1 Xf -0.1014317E+01 Yf 0.2497789E+01 Zf 0.5291833E+00 Face number 923006 badly oriented, block 1 Xf -0.1012213E+01 Yf 0.2537648E+01 Zf 0.5203373E+00 Face number 923714 badly oriented, block 1 Xf 0.4254758E-01 Yf 0.3395730E-01 Zf 0.2049814E+01 Nb of faces with orientation problem= 8 ***************************************** Warning: face orientation problem found. Warning: mesh quality check recommended. ***************************************** -994 Nb of faces with orientation problem= 8 # Grid quality summary: - Number of critical faces for non-orthogonals corrections: 3 - criterion: 0.500E+02 - min/max norm of explicit vectors: 0.296E-10 0.380E+03 Face number 859248 badly oriented, block 1 Xf 0.1604127E+02 Yf 0.2454893E+01 Zf 0.5219857E+00 Face number 859288 badly oriented, block 1 Xf 0.1603680E+02 Yf 0.2497697E+01 Zf 0.5316862E+00 Face number 859302 badly oriented, block 1 Xf 0.1604094E+02 Yf 0.2541203E+01 Zf 0.5222630E+00 Face number 871128 badly oriented, block 1 Xf 0.1708104E+02 Yf 0.2013228E-01 Zf 0.2057374E+01 Face number 871146 badly oriented, block 1 Xf 0.1711515E+02 Yf 0.4939139E-01 Zf 0.2051964E+01 Face number 923002 badly oriented, block 1 Xf 0.1606757E+02 Yf 0.2497789E+01 Zf 0.5291833E+00 Face number 923006 badly oriented, block 1 Xf 0.1606967E+02 Yf 0.2537648E+01 Zf 0.5203373E+00 Face number 923714 badly oriented, block 1 Xf 0.1712443E+02 Yf 0.3395730E-01 Zf 0.2049814E+01 Nb of faces with orientation problem= 8 ***************************************** Warning: face orientation problem found. Warning: mesh quality check recommended. ***************************************** -994 Nb of faces with orientation problem= 8 HISTORY OF THE CONVERGENCE OF NON-LINEARITIES --------------------------------------------- > BRICS Scheme : Max(Courant nb.) = 225.078104214421 -------------Fluid nb 1 o Residuals (Max & L2) : 0.444533686548725 1.454050274691410E-002 o Before limiting in [0,1] : - number of defects: 23531 - Min and Max (Ci) : -7.158960495852563E-002 1.09634401774981 o Max variation (Ci) : 0.163771114928892 Velocity is clipped on 367 points with Vmax= 22.5583694000000 Max of correction(Vel_Flux)= 9.850915306203500E-002 Residual of: d(Rho)/dt + Div(Rho.(U-Udep)) = 0 o Norm Linf : 242.399409983621 o Norm L2 : 7.561852196385456E-003 Residual of: Div(U) = 0 o Norm Linf : 1.521842008221846E-004 o Norm L2 : 6.160067898092618E-010 Velocity is clipped on 64 points with Vmax= 22.5583694000000 Max of correction(Velocity)= 0.4137968E+02 0.3564252E+03 0.6675535E+02 IT-NL RES(U) RES(V) RES(W) RES(P) DIV(U) RES(K) RES(w) SLVBLT MSEC/PTS 1 0.7839E+02 0.2108E+01 0.9206E+02 0.9912E-02 0.6160E-09 0.1657E-02 0.8190E+02 -0.1233E+00 0.1751E-01 Face number 859248 badly oriented, block 1 Xf -0.1040604E+01 Yf 0.2454894E+01 Zf 0.5212595E+00 Face number 859288 badly oriented, block 1 Xf -0.1045075E+01 Yf 0.2497697E+01 Zf 0.5309578E+00 Face number 859302 badly oriented, block 1 Xf -0.1040939E+01 Yf 0.2541201E+01 Zf 0.5215378E+00 Face number 871128 badly oriented, block 1 Xf -0.1154568E-02 Yf 0.2013065E-01 Zf 0.2056866E+01 Face number 871146 badly oriented, block 1 Xf 0.3296089E-01 Yf 0.4939209E-01 Zf 0.2051461E+01 Face number 923002 badly oriented, block 1 Xf -0.1014307E+01 Yf 0.2497789E+01 Zf 0.5284460E+00 Face number 923006 badly oriented, block 1 Xf -0.1012201E+01 Yf 0.2537648E+01 Zf 0.5196004E+00 Face number 923714 badly oriented, block 1 Xf 0.4223805E-01 Yf 0.3395730E-01 Zf 0.2049298E+01 Nb of faces with orientation problem= 8 Warning: face orientation problem found. Warning: mesh quality check recommended. -994 Nb of faces with orientation problem= 8 Face number 859248 badly oriented, block 1 Xf 0.1604128E+02 Yf 0.2454894E+01 Zf 0.5212595E+00 Face number 859288 badly oriented, block 1 Xf 0.1603681E+02 Yf 0.2497697E+01 Zf 0.5309578E+00 Face number 859302 badly oriented, block 1 Xf 0.1604095E+02 Yf 0.2541201E+01 Zf 0.5215378E+00 Face number 871128 badly oriented, block 1 Xf 0.1708073E+02 Yf 0.2013065E-01 Zf 0.2056866E+01 Face number 871146 badly oriented, block 1 Xf 0.1711485E+02 Yf 0.4939209E-01 Zf 0.2051461E+01 Face number 923002 badly oriented, block 1 Xf 0.1606758E+02 Yf 0.2497789E+01 Zf 0.5284460E+00 Face number 923006 badly oriented, block 1 Xf 0.1606969E+02 Yf 0.2537648E+01 Zf 0.5196004E+00 Face number 923714 badly oriented, block 1 Xf 0.1712413E+02 Yf 0.3395730E-01 Zf 0.2049298E+01 Nb of faces with orientation problem= 8 Warning: face orientation problem found. Warning: mesh quality check recommended. -994 Nb of faces with orientation problem= 8 > BRICS Scheme : Max(Courant nb.) = 265.386892680767 -------------Fluid nb 1 o Residuals (Max & L2) : 0.230941278368792 7.190376395976324E-003 o Before limiting in [0,1] : - number of defects: 66136 - Min and Max (Ci) : -3.833842732456356E-002 1.06413597901598 o Max variation (Ci) : 0.149897634764476 Velocity is clipped on 345 points with Vmax= 22.5583694000000 Max of correction(Vel_Flux)= 3.469410759590964E-002 Residual of: d(Rho)/dt + Div(Rho.(U-Udep)) = 0 o Norm Linf : 125.487404192640 o Norm L2 : 3.742927248510822E-003 Residual of: Div(U) = 0 o Norm Linf : 1.597076367111194E-005 o Norm L2 : 1.226198665107495E-010 Velocity is clipped on 28 points with Vmax= 22.5583694000000 Max of correction(Velocity)= 0.3201628E+02 0.2489374E+03 0.4757061E+02 2 0.3925E+02 0.9277E+00 0.4607E+02 0.1117E-01 0.1226E-09 0.1215E-02 0.6689E+02 -0.1328E+00 0.1422E-01 Face number 859248 badly oriented, block 1 Xf 0.1604128E+02 Yf 0.2454894E+01 Zf 0.5213480E+00 Face number 859288 badly oriented, block 1 Xf 0.1603681E+02 Yf 0.2497697E+01 Zf 0.5310465E+00 Face number 859302 badly oriented, block 1 Xf 0.1604095E+02 Yf 0.2541202E+01 Zf 0.5216261E+00 Face number 871128 badly oriented, block 1 Xf 0.1708078E+02 Yf 0.2013086E-01 Zf 0.2056918E+01 Face number 871146 badly oriented, block 1 Xf 0.1711490E+02 Yf 0.4939201E-01 Zf 0.2051512E+01 Face number 923002 badly oriented, block 1 Xf 0.1606758E+02 Yf 0.2497789E+01 Zf 0.5285355E+00 Face number 923006 badly oriented, block 1 Xf 0.1606968E+02 Yf 0.2537648E+01 Zf 0.5196898E+00 Face number 923714 badly oriented, block 1 Xf 0.1712418E+02 Yf 0.3395730E-01 Zf 0.2049350E+01 Nb of faces with orientation problem= 8 ***************************************** Warning: face orientation problem found. Warning: mesh quality check recommended. ***************************************** -994 Nb of faces with orientation problem= 8 > BRICS Scheme : Max(Courant nb.) = 190.981704666196 -------------Fluid nb 1 o Residuals (Max & L2) : 0.128093861980737 3.735917928298818E-003 o Before limiting in [0,1] : - number of defects: 78574 - Min and Max (Ci) : -3.090690285329486E-002 1.07676663755792 o Max variation (Ci) : 0.132940303387179 Velocity is clipped on 335 points with Vmax= 22.5583694000000 Max of correction(Vel_Flux)= 1.667184936048059E-002 Residual of: d(Rho)/dt + Div(Rho.(U-Udep)) = 0 o Norm Linf : 70.0222413388971 o Norm L2 : 1.949373211833797E-003 Residual of: Div(U) = 0 o Norm Linf : 5.298003944859912E-005 o Norm L2 : 2.996599747420332E-010 Velocity is clipped on 46 points with Vmax= 22.5583694000000 Max of correction(Velocity)= 0.3127086E+02 0.2788277E+03 0.5595402E+02 3 0.1964E+02 0.4091E+00 0.2307E+02 0.1039E-01 0.2997E-09 0.1076E-02 0.5473E+02 -0.1307E+00 0.1525E-01 -994 Nb of faces with orientation problem= 8 > BRICS Scheme : Max(Courant nb.) = 3246.91350105017 -------------Fluid nb 1 o Residuals (Max & L2) : 7.923691541632250E-004 1.975126540289793E-005 o Before limiting in [0,1] : - number of defects: 59457 - Min and Max (Ci) : -4.602865204128494E-002 1.06962505344433 o Max variation (Ci) : 0.131696511114733 Velocity is clipped on 386 points with Vmax= 22.5583694000000 Max of correction(Vel_Flux)= 0.752984359829584 Residual of: d(Rho)/dt + Div(Rho.(U-Udep)) = 0 o Norm Linf : 3.07550084918881 o Norm L2 : 1.224134954429284E-005 Residual of: Div(U) = 0 o Norm Linf : 1.867666104225618E-003 o Norm L2 : 7.873178579058337E-009 Velocity is clipped on 110 points with Vmax= 22.5583694000000 Max of correction(Velocity)= 0.2502880E+03 0.2018698E+03 0.1646985E+04 11 0.3795E+00 0.6868E-01 0.2316E+01 0.6146E-02 0.7873E-08 0.4733E-03 0.1048E+02 -0.1321E+00 0.1426E-01 Face number 859248 badly oriented, block 1 Xf -0.1040603E+01 Yf 0.2454894E+01 Zf 0.5210313E+00 Face number 859288 badly oriented, block 1 Xf -0.1045073E+01 Yf 0.2497697E+01 Zf 0.5307290E+00 Face number 859302 badly oriented, block 1 Xf -0.1040937E+01 Yf 0.2541201E+01 Zf 0.5213099E+00 Face number 871128 badly oriented, block 1 Xf -0.1203956E-02 Yf 0.2013017E-01 Zf 0.2056674E+01 Face number 871146 badly oriented, block 1 Xf 0.3291261E-01 Yf 0.4939233E-01 Zf 0.2051270E+01 Face number 923002 badly oriented, block 1 Xf -0.1014305E+01 Yf 0.2497789E+01 Zf 0.5282134E+00 Face number 923006 badly oriented, block 1 Xf -0.1012199E+01 Yf 0.2537648E+01 Zf 0.5193679E+00 Face number 923714 badly oriented, block 1 Xf 0.4218765E-01 Yf 0.3395730E-01 Zf 0.2049102E+01 Nb of faces with orientation problem= 8 ***************************************** Warning: face orientation problem found. Warning: mesh quality check recommended. ***************************************** -994 Nb of faces with orientation problem= 8 Face number 859248 badly oriented, block 1 Xf 0.1604128E+02 Yf 0.2454894E+01 Zf 0.5210313E+00 Face number 859288 badly oriented, block 1 Xf 0.1603681E+02 Yf 0.2497697E+01 Zf 0.5307290E+00 Face number 859302 badly oriented, block 1 Xf 0.1604095E+02 Yf 0.2541201E+01 Zf 0.5213099E+00 Face number 871128 badly oriented, block 1 Xf 0.1708068E+02 Yf 0.2013017E-01 Zf 0.2056674E+01 Face number 871146 badly oriented, block 1 Xf 0.1711480E+02 Yf 0.4939233E-01 Zf 0.2051270E+01 Face number 923002 badly oriented, block 1 Xf 0.1606758E+02 Yf 0.2497789E+01 Zf 0.5282134E+00 Face number 923006 badly oriented, block 1 Xf 0.1606969E+02 Yf 0.2537648E+01 Zf 0.5193679E+00 Face number 923714 badly oriented, block 1 Xf 0.1712407E+02 Yf 0.3395730E-01 Zf 0.2049102E+01 Nb of faces with orientation problem= 8 ***************************************** Warning: face orientation problem found. Warning: mesh quality check recommended. ***************************************** -994 Nb of faces with orientation problem= 8 > BRICS Scheme : Max(Courant nb.) = 14969.0296211191 -------------Fluid nb 1 o Residuals (Max & L2) : 3.011890003531442E-003 7.704007879596610E-005 o Before limiting in [0,1] : - number of defects: 59551 - Min and Max (Ci) : -2.377359977624135E-002 1.06812471184368 o Max variation (Ci) : 0.177950761960406 Velocity is clipped on 385 points with Vmax= 22.5583694000000 Max of correction(Vel_Flux)= 0.502632480230635 Residual of: d(Rho)/dt + Div(Rho.(U-Udep)) = 0 o Norm Linf : 2.90099399378799 o Norm L2 : 4.029991956126440E-005 Residual of: Div(U) = 0 o Norm Linf : 6.183425463499714E-004 o Norm L2 : 4.308493166958979E-009 Velocity is clipped on 169 points with Vmax= 22.5583694000000 Max of correction(Velocity)= 0.4452304E+03 0.4055537E+03 0.1481444E+04 12 0.1425E+01 0.2825E+00 0.8169E+01 0.2849E-01 0.4308E-08 0.5644E-03 0.9054E+01 -0.1328E+00 0.1443E-01 >>> ??? GAIN IN NL RESIDUAL : 0.11E+02 >>> ??? GAIN IN PFD RESIDUAL: 0.13E+01 >>> CONVERGENCE SPEED : 0.88E-01 ORDERS/ITER. >>> 12 ITERATIONS FOR 0.11E+01 ORDERS > Body Vessel - Total wetted surface of body: 0.447589E+01 - YZ component wetted surface of body: 0.443529E+01 > Total wetted surface (all bodies) = 0.447589E+01 > YZ component wetted surface (all bodies) = 0.443529E+01 ************************************************* INFORMATION: Ci Discretization scheme: - Max Face Courant Number: Global: 0.14313E+05 Prox. FS: 0.48377E+02 WARNING! - Number of faces where Co > 0.3: Global: 1038111 Prox. FS: 98476 ************************************************* ------------------------------------------------------------- Histogram of Cell Courant number - Total number of data : 1124105 - Number of bins : 10 - Bin range: [ 0.00000E+00 0.20946E+05] ------------------------------------------------------------- index nb. data % bin bounds ------------------------------------------------------------- 0 0 0.00% <= 0.00000E+00 1 1124101 100.00% [ 0.00000E+00 0.20946E+04 ] 2 1 0.00% [ 0.20946E+04 0.41892E+04 ] 3 2 0.00% [ 0.41892E+04 0.62839E+04 ] 4 0 0.00% [ 0.62839E+04 0.83785E+04 ] 5 0 0.00% [ 0.83785E+04 0.10473E+05 ] 6 0 0.00% [ 0.10473E+05 0.12568E+05 ] 7 0 0.00% [ 0.12568E+05 0.14662E+05 ] 8 0 0.00% [ 0.14662E+05 0.16757E+05 ] 9 0 0.00% [ 0.16757E+05 0.18852E+05 ] 10 1 0.00% [ 0.18852E+05 0.20946E+05 ] 11 0 0.00% > 0.20946E+05 ------------------------------------------------------------- Residual of:d(Rho)/dt + Div(Rho.(U-Udep)) = 0 o Norm Linf : 2.90099399378799 o Norm L2 : 4.029991956126440E-005 CPU COST OF THE TIME STEP : 0.71E+02 SECONDS : 0.19E+00 MSEC/PTS TIME USED : 593.030 MINUTES *----------------------------------------------------------------------------------------------* TIME STEP : 604 TIME : 0.1057154E+02 ORDER 2 *----------------------------------------------------------------------------------------------* Number of negative volumes 1 Minimum volume found in block 1 VolMin= -2.603858726382577E-007 Local cell ID: 153461 Warning: cell ID in Hexpress is 153460 Coordinates of the center of this cell are: Xc 0.4824478E-01 Yc 0.3852739E-01 Zc 0.2064472E+01 Coordinates of the face centres for this cell are: Xf 0.4789403E-01 Yf 0.3944186E-01 Zf 0.2064509E+01 Xf 0.6034360E-01 Yf 0.2113700E-01 Zf 0.2062384E+01 Xf 0.1709028E-01 Yf 0.3825167E-01 Zf 0.2063414E+01 Xf 0.4104127E-01 Yf 0.4936973E-01 Zf 0.2065804E+01 Xf 0.7096547E-01 Yf 0.4068191E-01 Zf 0.2065312E+01 Xf 0.5060478E-01 Yf 0.3395730E-01 Zf 0.2064007E+01 Maximum volume found in block 1 Volmax= 2.83896391021058 Local cell ID: 344843 Coordinates of the center of this cell are: Xc 0.4797671E+00 Yc 0.7063831E+00 Zc -0.4125077E+01 Coordinates of the face centres for this cell are: Xf 0.1280510E+00 Yf 0.3532417E+00 Zf -0.3408694E+01 Xf 0.8321556E+00 Yf 0.3531726E+00 Zf -0.3413684E+01 Xf 0.8327910E+00 Yf 0.1059686E+01 Zf -0.3414432E+01 Xf 0.1286175E+00 Yf 0.1059626E+01 Zf -0.3409462E+01 Xf 0.4785880E+00 Yf 0.7064390E+00 Zf -0.4837879E+01 Xf -0.2244982E+00 Yf 0.7063797E+00 Zf -0.4120452E+01 Xf 0.4794271E+00 Yf 0.0000000E+00 Zf -0.4124535E+01 Xf 0.4804950E+00 Yf 0.1412852E+01 Zf -0.4125731E+01 Xf 0.1184289E+01 Yf 0.7063774E+00 Zf -0.4129818E+01 Negative volume found in block 1 Computation stops because of negative volumes ! All parallel processes stopped by block 1 application called MPI_Abort(MPI_COMM_WORLD, 1) - process 0 Please help me to solve these problem thank you |
OpenFOAM and seakeeping | Fauster | OpenFOAM Running, Solving & CFD | 0 | May 12, 2017 08:35 |
Strange Experience with DFBI Seakeeping Simulation | Forbin | STAR-CCM+ | 2 | April 28, 2015 15:48 |
Problems Running Seakeeping Analysis in Headwave | JeffStrath | STAR-CCM+ | 0 | April 28, 2015 14:37 |
DFBI Seakeeping Simulation | Forbin | STAR-CCM+ | 8 | October 17, 2013 09:36 |
seakeeping - software or code | Renato Skejic | Main CFD Forum | 0 | May 25, 2000 21:00 |
