Home > Forums > Software User Forums > OpenFOAM > OpenFOAM News & Announcements > OpenFOAM Announcements from OpenFOAM Foundation
OpenFOAM Foundation releases OpenFOAM® 2.4.0
Like Tree8Likes
  • 8 Post By CFDFoundation
Old   May 22, 2015, 10:41
Default OpenFOAM Foundation releases OpenFOAM® 2.4.0
CFDFoundation is on a distinguished road
The OpenFOAM Foundation is pleased to announce the release of version 2.4.0 of the OpenFOAM open source CFD toolbox. The version number 2.4.0 has been chosen following a request on the issue tracking system to adopt semantic version numbering. Our numbering system is now MAJOR.MINOR.PATCH, where:
  • MAJOR: breaks backward compatibility for usage, e.g. case files require changes;
  • MINOR: changes some internal API, but backward compatible usage;
  • PATCH: bug fixes that do not change internal API.
Based on this, v2.4.0 represents a minor release with changes to some internal API, some new features described below, particularly relating to pre- and post-processing, and further bug fixes of version 2.3.1. (The next major release will then be v3.0.0 based on functionality in the current OpenFOAM-dev repository.) OpenFOAM v2.4.0 includes over 200 code commits and almost 800 file changes. It is distributed under the General Public Licence by the OpenFOAM Foundation as:
Pre-processing Meshing
  • blockMesh now supports multiple mesh grading within a single mesh block: further details…
  • extrudeMesh includes new wedge and plane extrusions added for easy set up of axi-symmetric and 2D geometries: further details…
  • refineMesh has improved command line argument handling: further details…
Thermophysical modelling
  • Thermal baffles with multiple material layers with different thermal conductivities now correctly supported: further details…
Multiphase modelling
  • Interface capturing has been made 2nd-order accurate in time, to preserve surface waves effectively: further details…
Post-processing OpenFOAM v2.4.0 was produced by:
  • Architect/Lead: Henry Weller
  • Management: Henry Weller, Chris Greenshields
  • Maintenance/Testing/Contributions: Henry Weller, Chris Greenshields, Bruno Santos, Richard Jones
  • Other Contributions: Mattijs Janssens, Daniel Jasinski, Alexey Matveichev, Juho Peltola, Timm Severin
Thanks to the OpenFOAM enthusiasts who have contributed to a better code through the bug reporting system.
To download OpenFOAM 2.4.0, click here.
wyldckat, olivierG, romant and 5 others like this.
CFDFoundation is offline   Reply With Quote
2.4.0, foundation, openfoam
Getting Started with OpenFOAM wyldckat OpenFOAM 25 August 14, 2022 13:55
OpenFOAM Introductory Course at Politecnico di Milano, March 3-5 2015 lucchini OpenFOAM Announcements from Other Sources 0 January 15, 2015 11:17
7th OpenFOAM Workshop holger_marschall OpenFOAM Announcements from Other Sources 56 October 27, 2012 13:28
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 06:25
