Strange interPhaseChangeFoam behavior after restart |
#1 | |
Giovanni Caramia
Rep Power: 17 ![]() |
Hi all,
I am using interPhaseChangeFoam (OpenFOAM-dev) solver and I am experiencing difficoulties similar to those described by vkrastev in his post even if the solver is different. The solution to those problems was well explained by Alberto Passalacqua: Quote:
with interPhaseChangeFoam. Inside the attached tar file there are four time directories 0, 1, 2, 3:
Could this be reported as a bug of the interPhaseChangeFoam solver or I'm doing something wrong? Thank you very much! |
Giovanni Caramia
OK,
I am trying to trace through which fields are different between the continuous run and the restart but I am not able to find where in the source code it is written to read the alpha.water field. Can someone please help me? |
strange behavior in interPhaseChangeFoam | huangxianbei | OpenFOAM Running, Solving & CFD | 5 | May 21, 2017 15:28 |
Different implementation pEqn.H in pimpleFoam vs interPhaseChangeFoam | DanielRCalvete | OpenFOAM Programming & Development | 1 | December 4, 2015 10:37 |
interphasechangeFoam: strange residual behaviour with keps and kwSST | shipman | OpenFOAM Post-Processing | 1 | June 14, 2014 08:58 |
Strange rhoCentralFoam behavior after restart... | vkrastev | OpenFOAM Bugs | 27 | November 19, 2013 12:04 |
Problem with multiframe restart of two-way fsi coupled problem | Dimone | CFX | 26 | December 20, 2011 10:10 |
