Different results mixing plane foam ext 3.2 & 4.0 |
July 29, 2018, 14:52 |
Enrico De Filippi
Rep Power: 7 |
Hi guys, I'm studying an axial turbine, so to solve my stator and rotor fields I'm using mixing plane. The problem is that using steadyCompressibleMRFFoam with foam extend 3.2 all works fine while with 4.0 it takes to unphysical solution.
I can't use the 3.2 because I've to work with real gas whose library is not implemented in foam 3.2. I've already checked the source file in the finiteVolume and foam/meshes folder about mixingPlane trying to make the 4.0 more similar as possibile to the 3.2. Did anybody of you already face this problem? Do you have any suggestion? I leave the different results I get with 3.2 and 4.0 version: Flux divergence min = 0.000232183584313 max = 1824125.33839 average: 1101.45637728 Mach number min = 0.00190838717129 max = 2.00273908446 Field U magnitude min = 0 max = 856.643527779 Field p min = 42331.9029619 max = 510310.051604 Field rho min = 0.306032525316 max = 7.79979800637 Field T min = 200 max = 500 Mixing plane pair (Outflow_stator, Inflow_rotor) : 0.345041766478 -0.345509719296 Diff = -0.000467952818715 or 0.135622079464 % Flux divergence min = 4.55157280307e-05 max = 249609.441799 average: 114.297658371 Mach number min = 2.98841685868e-05 max = 2.5808451657 Field U magnitude min = 0 max = 500 Field p min = 5444.94477356 max = 1000000 Field rho min = 0.00619202851425 max = 17.379256264 Field T min = 3.19875761314 max = 7469.41474673 Mixing plane pair (Outflow_stator, Inflow_rotor) : 0.00214541998123 0.000282009095223 Diff = 0.00242742907645 or 113.144703493 % Thanks in advance. |
conjugateHeatFoam: regionCoupling boundary in foam 3.0 ext | ahmmedshakil | OpenFOAM Programming & Development | 0 | September 27, 2014 09:26 |
Problem with Mixing plane | Mitpostdoc | FLUENT | 0 | July 26, 2011 14:31 |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 13:06 |
Meshing a Mixing Plane using ICEM | Will Anderson | FLUENT | 0 | November 6, 2010 17:08 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
