Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Sig Turbomachinary compilation error
Old   July 12, 2019, 15:44
Unhappy Sig Turbomachinary compilation error
Milan
Milan Shrestha is on a distinguished road
I have got problem during compilation in OpenFOAM 2.0 dev by executing command ./Allwmake in openfoam-extend-Breeder2.0-OSIG-TurboMachinery-master/src
But I got long list of error. which is something like this:
profile1DfixedValueFvPatchField.C:148:34: error: no matching function
(blah blah)
/opt/openfoam-dev/src/OpenFOAM/lnInclude/Field.C:184:1: note:   candidate expects 3 arguments, 2 provided
/opt/openfoam-dev/src/OpenFOAM/lnInclude/Field.C:177:1: note: candidate: Foam::Field<Type>::Field(Foam::Istream&) [with Type = Foam::Vector<double>]
 Foam::Field<Type>::Field(Istream& is)
/opt/openfoam-dev/src/OpenFOAM/lnInclude/Field.C:177:1: note:   candidate expects 1 argument, 2 provided
/opt/openfoam-dev/src/OpenFOAM/lnInclude/Field.C:163:1: note: candidate: Foam::Field<Type>::Field(const Foam::tmp<Foam::Field<Type> >&, const labelListList&, const scalarListList&) [with Type = Foam::Vector<double>; Foam::labelListList = Foam::List<Foam::List<int> >; Foam::scalarListList = Foam::List<Foam::List<double> >]
finiteVolume/fields/fvPatchFields/derived/profile1DfixedValue/profile1DfixedValueFvPatchField.C: In instantiation of ‘void Foam::profile1DfixedValueFvPatchField<Type>::autoMap(const Foam::fvPatchFieldMapper&) [with Type = Foam::SymmTensor<double>]’:
finiteVolume/fields/fvPatchFields/derived/profile1DfixedValue/profile1DfixedValueFvPatchFields.C:51:1:   required from here
finiteVolume/fields/fvPatchFields/derived/profile1DfixedValue/profile1DfixedValueFvPatchField.C:390:25: error: ‘autoMap’ is not a member of ‘Foam::Field<Foam::SymmTensor<double> >’
     Field<Type>::autoMap(m);
finiteVolume/fields/fvPatchFields/derived/profile1DfixedValue/profile1DfixedValueFvPatchField.C:391:5: error: ‘class Foam::Field<Foam::SymmTensor<double> >’ has no member named ‘autoMap’
     profile1DValue_.autoMap(m);
Configuration:
  Source code location:       .
  Compiler CC:                gcc
  Compiler CC flags:          -g -O2
  Compiler CXX:               g++
  Compiler CXX flags:         -g -O2
  Host System Type:           x86_64-unknown-linux-gnu
  Install path:               /home/linux/Downloads/openfoam-extend-Breeder2.0-OSIG-TurboMachinery-master/src/libcgnsoo_3.0/platforms/linux64GccDPInt32Opt
  CGNSLIB_HOME path:          /home/linux/Downloads/openfoam-extend-Breeder2.0-OSIG-TurboMachinery-master/src/cgnslib_2.5/platforms/linux64GccDPInt32Opt
  See config.h for further configuration information.
+ make
cd . && aclocal -I config
/bin/bash: aclocal: command not found
Makefile:231: recipe for target 'aclocal.m4' failed
make: *** [aclocal.m4] Error 127
+ make install
+ popd
~/Downloads/openfoam-extend-Breeder2.0-OSIG-TurboMachinery-master/src
root@linux-VirtualBox:~/Downloads/openfoam-extend-Breeder2.0-OSIG-TurboMachinery-master/src#
What could be the possible solution? I have been trying to do my final year project in turbomachinary in OpenFOM but I got an issue during compilation. So, please help me out.
Thank you in advance.
Regards,
Milan
Milan Shrestha is offline   Reply With Quote
compilation error, compile error, profile1dfixedvalue, turbomachinery
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 09:00
Pressure outlet boundary condition rolando OpenFOAM Running, Solving & CFD 62 September 18, 2017 06:45
DPM udf error haghshenasfard FLUENT 0 April 13, 2016 06:35
[OpenFOAM] Native ParaView Reader Bugs tj22 ParaView 270 January 4, 2016 11:39
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 17:38
