Total Pressure BC for High-speed compressible flow - erroneous activation conditions |
August 5, 2019, 16:14 |
A. Z.
Rep Power: 7 |
Trying to derive the totalPressure boundary condition for a specific use, I found that the conditions for the selection between transonic and supersonic regimes for High-speed compressible flow are not consistent with the aerodynamic definition of these regimes. These conditions are associated with \gamma (specific heat ratios), where they should depend on the speed at least (Mach number). See the script here below from: fields/fvPatchFields/derived/totalPressure/totalPressureFvPatchScalarField.C (OpenFOAM-5.x) ################################################## ########################## Code:
else { // High-speed compressible flow const fvPatchField<scalar>& psip = patch().lookupPatchField<volScalarField, scalar>(psiName_); if (gamma_ > 1) { scalar gM1ByG = (gamma_ - 1)/gamma_; operator== ( p0p /pow ( (1.0 + 0.5*psip*gM1ByG*(1.0 - pos0(phip))*magSqr(Up)), 1.0/gM1ByG ) ); } else { operator==(p0p/(1.0 + 0.5*psip*(1.0 - pos0(phip))*magSqr(Up))); } } This may induce errors, any comment or suggestion regarding the way to proceed with this? Thanks. Zi Aun. Last edited by Zi_Aun; August 5, 2019 at 19:16. Reason: Add of the traditional "Hello" |
gamma, totalpressure bc |
Pressure Outlet Targeted Mass Flow Rate | LuckyTran | FLUENT | 1 | November 23, 2016 10:40 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
Problem with SIMPLEC-like finite volume channel flow boundary conditions | ghobold | Main CFD Forum | 3 | June 15, 2015 11:14 |
Boundary Conditions : Total Pressure or Velocity | Gearb0x | OpenFOAM Running, Solving & CFD | 2 | February 28, 2011 21:18 |
Total pressure in real gas (compressible flow) | Bart Prast | Main CFD Forum | 3 | November 14, 2000 10:44 |
