Unacceptable deltaT value (like 3e-107) Error |
February 10, 2020, 03:45 |
saidc
Rep Power: 6 |
Hi, I'm getting an error. I've tried a lot of things but i didn't solve my problem. My solver is interFoam. Just look at the deltaT (like 3e-107) and alpha.water (like 3e-64) values in error file and you can see the Time value is never changing. Why i'm getting this error? How can i fix this?
(I used SolidWorks 2016, salome 8.4.0, openfoam-7, ubuntu 18.04 and i customized classic laminar/damBreak case.) boundary Code:
{ version 2.0; format ascii; class polyBoundaryMesh; location "constant/polyMesh"; object boundary; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // 5 ( leftWall { type wall; inGroups List<word> 1(wall); nFaces 116; startFace 26049; } rightWall { type wall; inGroups List<word> 1(wall); nFaces 80; startFace 26165; } lowerWall { type wall; inGroups List<word> 1(wall); nFaces 136; startFace 26245; } atmosphere { type patch; nFaces 120; startFace 26381; } defaultFaces { type empty; inGroups List<word> 1(empty); nFaces 9918; startFace 26501; } ) // ************************************************************************* // Code:
FoamFile { version 2.0; format ascii; class volScalarField; object alpha.water; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 0 0 0 0 0 0]; internalField uniform 0; boundaryField { leftWall { type zeroGradient; } rightWall { type zeroGradient; } lowerWall { type zeroGradient; } atmosphere { type inletOutlet; inletValue uniform 0; value uniform 0; } defaultFaces { type empty; } } Code:
FoamFile { version 2.0; format ascii; class volScalarField; object p_rgh; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform 0; boundaryField { leftWall { type fixedFluxPressure; value uniform 0; } rightWall { type fixedFluxPressure; value uniform 0; } lowerWall { type fixedFluxPressure; value uniform 0; } atmosphere { type totalPressure; p0 uniform 0; } defaultFaces { type empty; } } Code:
FoamFile { version 2.0; format ascii; class volVectorField; location "0"; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { leftWall { type noSlip; } rightWall { type noSlip; } lowerWall { type noSlip; } atmosphere { type pressureInletOutletVelocity; value uniform (0 0 0); } defaultFaces { type empty; } } Code:
smoothSolver: Solving for alpha.water, Initial residual = 5.98474e-05, Final residual = 3.88048e-11, No Iterations 2 Phase-1 volume fraction = 0.0746171 Min(alpha.water) = -4.44338e-68 Max(alpha.water) = 1 MULES: Correcting alpha.water MULES: Correcting alpha.water Phase-1 volume fraction = 0.0746171 Min(alpha.water) = -3.52175e-17 Max(alpha.water) = 1 DICPCG: Solving for p_rgh, Initial residual = 0.781862, Final residual = 0.0317406, No Iterations 8 time step continuity errors : sum local = 0.000492867, global = -3.45236e-08, cumulative = 0.00744918 DICPCG: Solving for p_rgh, Initial residual = 0.608476, Final residual = 0.0248548, No Iterations 8 time step continuity errors : sum local = 0.00162432, global = 1.66769e-08, cumulative = 0.0074492 DICPCG: Solving for p_rgh, Initial residual = 0.618346, Final residual = 9.228e-08, No Iterations 362 time step continuity errors : sum local = 2.749e-08, global = -8.68054e-10, cumulative = 0.0074492 ExecutionTime = 35.66 s ClockTime = 36 s Courant Number mean: 0.0396433 max: 17.064 Interface Courant Number mean: 0.00390682 max: 5.60411 deltaT = 7.77403e-100 Time = 0.00119069 smoothSolver: Solving for alpha.water, Initial residual = 5.84367e-05, Final residual = 3.60982e-11, No Iterations 2 Phase-1 volume fraction = 0.0746171 Min(alpha.water) = -4.44162e-68 Max(alpha.water) = 1 MULES: Correcting alpha.water MULES: Correcting alpha.water Phase-1 volume fraction = 0.0746171 Min(alpha.water) = -5.0219e-17 Max(alpha.water) = 1 DICPCG: Solving for p_rgh, Initial residual = 0.779072, Final residual = 0.0316353, No Iterations 8 time step continuity errors : sum local = 7.53892e-05, global = -4.91121e-09, cumulative = 0.00744919 DICPCG: Solving for p_rgh, Initial residual = 0.607604, Final residual = 0.0248692, No Iterations 8 time step continuity errors : sum local = 0.000248544, global = 2.35874e-09, cumulative = 0.00744919 DICPCG: Solving for p_rgh, Initial residual = 0.616997, Final residual = 9.84716e-08, No Iterations 362 time step continuity errors : sum local = 4.46598e-09, global = -1.34046e-10, cumulative = 0.00744919 ExecutionTime = 36.11 s ClockTime = 37 s Courant Number mean: 0.00599844 max: 2.59439 Interface Courant Number mean: 0.000588719 max: 0.891569 deltaT = 1.49824e-100 Time = 0.00119069 smoothSolver: Solving for alpha.water, Initial residual = 5.73287e-05, Final residual = 3.53128e-11, No Iterations 2 Phase-1 volume fraction = 0.0746171 Min(alpha.water) = -4.43785e-68 Max(alpha.water) = 1 MULES: Correcting alpha.water MULES: Correcting alpha.water Phase-1 volume fraction = 0.0746171 Min(alpha.water) = -6.81171e-17 Max(alpha.water) = 1 DICPCG: Solving for p_rgh, Initial residual = 0.776517, Final residual = 0.0313868, No Iterations 8 time step continuity errors : sum local = 0.00048802, global = -2.93771e-08, cumulative = 0.00744916 DICPCG: Solving for p_rgh, Initial residual = 0.606532, Final residual = 0.0247253, No Iterations 8 time step continuity errors : sum local = 0.00160604, global = 1.3903e-08, cumulative = 0.00744918 DICPCG: Solving for p_rgh, Initial residual = 0.615519, Final residual = 9.41518e-08, No Iterations 340 time step continuity errors : sum local = 2.75985e-08, global = -1.00355e-09, cumulative = 0.00744918 ExecutionTime = 36.54 s ClockTime = 37 s Courant Number mean: 0.0385174 max: 16.7802 Interface Courant Number mean: 0.00380786 max: 6.09569 deltaT = 4.4643e-102 Time = 0.00119069 smoothSolver: Solving for alpha.water, Initial residual = 5.61634e-05, Final residual = 3.3963e-11, No Iterations 2 Phase-1 volume fraction = 0.0746171 Min(alpha.water) = -4.42924e-68 Max(alpha.water) = 1 MULES: Correcting alpha.water MULES: Correcting alpha.water Phase-1 volume fraction = 0.0746171 Min(alpha.water) = -4.35845e-17 Max(alpha.water) = 1 DICPCG: Solving for p_rgh, Initial residual = 0.773262, Final residual = 0.0307347, No Iterations 8 time step continuity errors : sum local = 7.27895e-05, global = -3.94879e-09, cumulative = 0.00744917 DICPCG: Solving for p_rgh, Initial residual = 0.604857, Final residual = 0.024329, No Iterations 8 time step continuity errors : sum local = 0.000239488, global = 2.02513e-09, cumulative = 0.00744917 DICPCG: Solving for p_rgh, Initial residual = 0.613341, Final residual = 9.64352e-08, No Iterations 362 time step continuity errors : sum local = 4.2589e-09, global = -1.19707e-10, cumulative = 0.00744917 ExecutionTime = 36.98 s ClockTime = 38 s Courant Number mean: 0.00578662 max: 2.56257 Interface Courant Number mean: 0.000578441 max: 0.973182 deltaT = 8.71061e-103 Time = 0.00119069 smoothSolver: Solving for alpha.water, Initial residual = 5.49118e-05, Final residual = 3.2171e-11, No Iterations 2 Phase-1 volume fraction = 0.0746171 Min(alpha.water) = -4.4112e-68 Max(alpha.water) = 1 MULES: Correcting alpha.water MULES: Correcting alpha.water Phase-1 volume fraction = 0.0746171 Min(alpha.water) = -3.96341e-16 Max(alpha.water) = 1 DICPCG: Solving for p_rgh, Initial residual = 0.770017, Final residual = 0.0299674, No Iterations 8 time step continuity errors : sum local = 0.000454079, global = -2.18559e-08, cumulative = 0.00744915 DICPCG: Solving for p_rgh, Initial residual = 0.602994, Final residual = 0.0293486, No Iterations 5 time step continuity errors : sum local = 0.00183973, global = 9.67059e-08, cumulative = 0.00744925 DICPCG: Solving for p_rgh, Initial residual = 0.620295, Final residual = 9.23708e-08, No Iterations 342 time step continuity errors : sum local = 2.46046e-08, global = -9.39872e-11, cumulative = 0.00744925 ExecutionTime = 37.41 s ClockTime = 38 s Courant Number mean: 0.0322515 max: 17.5305 Interface Courant Number mean: 0.00359975 max: 6.76509 deltaT = 2.48441e-104 Time = 0.00119069 smoothSolver: Solving for alpha.water, Initial residual = 4.83567e-05, Final residual = 1.91459e-11, No Iterations 2 Phase-1 volume fraction = 0.0746171 Min(alpha.water) = -1.04402e-46 Max(alpha.water) = 1 MULES: Correcting alpha.water MULES: Correcting alpha.water Phase-1 volume fraction = 0.0746171 Min(alpha.water) = -2.51392e-17 Max(alpha.water) = 1 DICPCG: Solving for p_rgh, Initial residual = 0.742106, Final residual = 0.0363213, No Iterations 7 time step continuity errors : sum local = 6.49571e-05, global = -5.59286e-11, cumulative = 0.00744925 DICPCG: Solving for p_rgh, Initial residual = 0.606875, Final residual = 0.0274085, No Iterations 5 time step continuity errors : sum local = 0.000207145, global = 4.45286e-09, cumulative = 0.00744925 DICPCG: Solving for p_rgh, Initial residual = 0.619751, Final residual = 9.17399e-08, No Iterations 362 time step continuity errors : sum local = 3.04518e-09, global = -6.90435e-11, cumulative = 0.00744925 ExecutionTime = 37.86 s ClockTime = 38 s Courant Number mean: 0.0040732 max: 2.24028 Interface Courant Number mean: 0.000418459 max: 0.609483 deltaT = 5.54488e-105 Time = 0.00119069 smoothSolver: Solving for alpha.water, Initial residual = 4.76685e-05, Final residual = 2.01965e-11, No Iterations 2 Phase-1 volume fraction = 0.0746171 Min(alpha.water) = -9.91398e-47 Max(alpha.water) = 1 MULES: Correcting alpha.water MULES: Correcting alpha.water Phase-1 volume fraction = 0.0746171 Min(alpha.water) = -3.04471e-17 Max(alpha.water) = 1 DICPCG: Solving for p_rgh, Initial residual = 0.744592, Final residual = 0.0363254, No Iterations 5 time step continuity errors : sum local = 0.000498639, global = 1.99994e-08, cumulative = 0.00744927 DICPCG: Solving for p_rgh, Initial residual = 0.623883, Final residual = 0.0268522, No Iterations 5 time step continuity errors : sum local = 0.00154667, global = -3.01824e-08, cumulative = 0.00744924 DICPCG: Solving for p_rgh, Initial residual = 0.613925, Final residual = 9.08759e-08, No Iterations 363 time step continuity errors : sum local = 2.22317e-08, global = -4.95163e-10, cumulative = 0.00744924 ExecutionTime = 38.34 s ClockTime = 39 s Courant Number mean: 0.0304221 max: 16.379 Interface Courant Number mean: 0.00306763 max: 4.27059 deltaT = 1.69268e-106 Time = 0.00119069 smoothSolver: Solving for alpha.water, Initial residual = 4.75175e-05, Final residual = 1.99622e-11, No Iterations 2 Phase-1 volume fraction = 0.0746171 Min(alpha.water) = -4.24586e-68 Max(alpha.water) = 1 MULES: Correcting alpha.water MULES: Correcting alpha.water Phase-1 volume fraction = 0.0746171 Min(alpha.water) = -3.42133e-17 Max(alpha.water) = 1 DICPCG: Solving for p_rgh, Initial residual = 0.743859, Final residual = 0.0325512, No Iterations 5 time step continuity errors : sum local = 6.12945e-05, global = 4.61408e-09, cumulative = 0.00744925 DICPCG: Solving for p_rgh, Initial residual = 0.616162, Final residual = 0.0244443, No Iterations 5 time step continuity errors : sum local = 0.000188544, global = -8.24671e-09, cumulative = 0.00744924 DICPCG: Solving for p_rgh, Initial residual = 0.605392, Final residual = 9.66245e-08, No Iterations 362 time step continuity errors : sum local = 3.08855e-09, global = -3.55315e-11, cumulative = 0.00744924 ExecutionTime = 38.79 s ClockTime = 39 s Courant Number mean: 0.0042222 max: 2.28614 Interface Courant Number mean: 0.000412843 max: 0.511151 deltaT = 3.70205e-107 Time = 0.00119069 smoothSolver: Solving for alpha.water, Initial residual = 4.32103e-05, Final residual = 1.9414e-11, No Iterations 2 Phase-1 volume fraction = 0.0746171 Min(alpha.water) = -4.1624e-68 Max(alpha.water) = 1 MULES: Correcting alpha.water MULES: Correcting alpha.water Phase-1 volume fraction = 0.0746171 Min(alpha.water) = -2.01258e-17 Max(alpha.water) = 1 #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 double Foam::sumProd<double>(Foam::UList<double> const&, Foam::UList<double> const&) at ??:? #4 Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? #5 Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:? #6 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/interFoam" #7 Foam::fvMatrix<double>::solve() in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/interFoam" #8 ? in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/interFoam" #9 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #10 ? in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/interFoam" |
March 6, 2020, 01:38 |
Andreas P.
Rep Power: 9 |
Probably your time precision is too low, so that the 3e-107 is treated as a 0. I don't think you will be able to have time precision so high to use such small time steps...
deltat, error, mesh, openfoam-7 |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 09:00 |
[OpenFOAM] Native ParaView Reader Bugs | tj22 | ParaView | 270 | January 4, 2016 11:39 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
Errors in UDF | shashank312 | Fluent UDF and Scheme Programming | 6 | May 30, 2013 20:30 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
