Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Problem with tutorialcase damBreak4phase under OpenFOAM15dev
Old   February 7, 2009, 03:53
Default I'm using OpenFOAM-1.5-dev (sv
jfb
Josef F. Buergler
jfb is on a distinguished road
I'm using OpenFOAM-1.5-dev (svn rev. 980), compiled it (openSUSE 10.3, 64bit) and get no errormessages when running foamInstallationTest.
When running the tutorial-case multiphaseInterFoam/damBreak4phase, at the end of the first time loop, the following error message is issued:
smoothSolver: Solving for alphamercury, Initial residual = 0, Final residual = 0, No Iterations 0
mercury volume fraction, min, max = 0.0443935 0 1
air volume fraction, min, max = 0.750462 0 1
GAMG: Solving for pd, Initial residual = 1, Final residual = 0.0490662, No Iterations 1
GAMG: Solving for pd, Initial residual = 0.0154804, Final residual = 0.000357115, No Iterations 3
GAMG: Solving for pd, Initial residual = 0.000276821, Final residual = 1.03939e-05, No Iterations 5
keyword smoother is undefined in dictionary ""
file: from line 0 to line 0.
From function dictionary::lookupEntry(const word& keyword) const
in file db/dictionary/dictionary.C at line 213.
FOAM exiting
Exactly the same case seems to run fine under OpenFOAM-1.5.x (latest "git pull").
Could somebody please shed some light on this? Thanks a lot for any help!
Josef
jfb is offline   Reply With Quote
Old   February 7, 2009, 04:09
Default I just tried multiphaseInterFo
henry is on a distinguished road
I just tried multiphaseInterFoam/damBreak4phase with 1.5.x and it ran without any problem.
H
henry is offline   Reply With Quote
Old   February 7, 2009, 04:46
Default Yes, this one is my bug: I hav
Hrvoje Jasak
hjasak will become famous soon enough
Yes, this one is my bug: I have just checked in the fix. It is to do with the format of the CD solver when GAMG is called as a preconditioner.
It runs over there, the fix is in tutorials/multiphaseInterFoam/damBreak4phase/system/fvSolution
Apologies,
Hrv
Hrvoje Jasak
Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk
hjasak is offline   Reply With Quote
Old   February 9, 2009, 04:59
Default Thanks very much for Your answ
jfb
Josef F. Buergler
Thanks very much for Your answers! Tha case runs now with both versions :-)
Regards - Josef
Old   June 4, 2010, 04:33
Default fvsolution dictionary bug
Aldo Iannetti
aldo.iannetti is on a distinguished road
Hi josef
can you explane better how you fixed the fvsolution dictionary bug? I have the same error on OF 1.5-dev using an interfoam tutorial, I have the following error:
FOAM exiting
Can you explane exactly how to fix it, I'm new with OF.
Thanks
Aldo
Regards - Josef
aldo.iannetti is offline   Reply With Quote
Old   January 22, 2024, 13:05
Default preconditioner should be mofified
atilla altintas
galoisati is on a distinguished road
If anyone face with this error, solution is checking the compatibility of the preconditioner with the smoother.
I solved this error by changing the preconditioner GAMG to diagonal (you may try others also such as DIC, DILU etc.)
Hope that helps someone.
galoisati is offline   Reply With Quote
OpenFOAM15dev interDyMFoam problem using dynamicRefineFvMesh eberberovic OpenFOAM Bugs 6 January 14, 2010 05:18
Installation of OpenFOAM15dev antonio_ing OpenFOAM Installation 34 December 18, 2009 10:06
Help Error Installation of openfoam15dev loneboard OpenFOAM Installation 4 February 4, 2009 09:24
About OpenFOAM15dev waynezw0618 OpenFOAM Running, Solving & CFD 5 January 21, 2009 17:55
Problems with tutorialcase multiphaseInterFoam damBreak4phaseFine jfb OpenFOAM Bugs 2 February 29, 2008 06:20
